on 12-01-2022 17:39
Ive been having nothing but issues with my internets latency, constantly lagging while gaming with packet loss and latency errors since the day i got the internet installed.
I have gone through all the steps, resetting and restarting. Nothings helped.
Answered! Go to Answer
on 27-01-2022 13:47
Hi again @Bradleygraham84
Thanks so much for your private message and confirming your address, I have now booked you a visit for connection issues – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Thank you.
on 02-02-2022 13:12
Hi there,
Thank you so much for reaching out to me via the PM and I am so sorry to hear that you are experiencing continued issues after the engineer visit and new Hub.
Per our PM conversation are you able to post your Hub status and logs for us? To do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link'.
Thank you
on 02-02-2022 20:01
https://www.thinkbroadband.com/broadband/monitoring/quality/share/29c87e0c35356d6bd7cfee57afb99351eda499fb
Acquired Downstream Channel (Hz) | 227000000 | Locked |
Ranged Upstream Channel (Hz) | 46200014 | Locked |
Provisioning State | Online |
1 | 227000000 | 1.5 | 38 | 256 qam | 12 |
2 | 139000000 | 2.2 | 37 | 256 qam | 1 |
3 | 147000000 | 2.4 | 37 | 256 qam | 2 |
4 | 155000000 | 2.5 | 38 | 256 qam | 3 |
5 | 163000000 | 2.5 | 38 | 256 qam | 4 |
6 | 171000000 | 2.5 | 38 | 256 qam | 5 |
7 | 179000000 | 2.2 | 38 | 256 qam | 6 |
8 | 187000000 | 2.2 | 38 | 256 qam | 7 |
9 | 195000000 | 2.2 | 38 | 256 qam | 8 |
10 | 203000000 | 2 | 38 | 256 qam | 9 |
11 | 211000000 | 1.7 | 38 | 256 qam | 10 |
12 | 219000000 | 1.7 | 38 | 256 qam | 11 |
13 | 235000000 | 1.5 | 38 | 256 qam | 13 |
14 | 243000000 | 1.2 | 38 | 256 qam | 14 |
15 | 251000000 | 1.2 | 38 | 256 qam | 15 |
16 | 259000000 | 1.4 | 38 | 256 qam | 16 |
17 | 267000000 | 1.5 | 38 | 256 qam | 17 |
18 | 275000000 | 1.2 | 38 | 256 qam | 18 |
19 | 283000000 | 1.4 | 38 | 256 qam | 19 |
20 | 291000000 | 1.4 | 38 | 256 qam | 20 |
21 | 299000000 | 1.9 | 38 | 256 qam | 21 |
22 | 307000000 | 1.7 | 38 | 256 qam | 22 |
23 | 315000000 | 1.7 | 38 | 256 qam | 23 |
24 | 323000000 | 2.2 | 38 | 256 qam | 24 |
1 | Locked | 38.6 | 53 | 0 |
2 | Locked | 37.6 | 67 | 0 |
3 | Locked | 37.6 | 58 | 0 |
4 | Locked | 38.9 | 59 | 0 |
5 | Locked | 38.9 | 64 | 0 |
6 | Locked | 38.9 | 72 | 0 |
7 | Locked | 38.9 | 80 | 0 |
8 | Locked | 38.9 | 91 | 0 |
9 | Locked | 38.6 | 58 | 0 |
10 | Locked | 38.9 | 57 | 0 |
11 | Locked | 38.6 | 45 | 0 |
12 | Locked | 38.9 | 51 | 0 |
13 | Locked | 38.6 | 56 | 0 |
14 | Locked | 38.6 | 70 | 0 |
15 | Locked | 38.6 | 58 | 0 |
16 | Locked | 38.9 | 60 | 0 |
17 | Locked | 38.9 | 69 | 0 |
18 | Locked | 38.6 | 54 | 0 |
19 | Locked | 38.6 | 71 | 0 |
20 | Locked | 38.6 | 60 | 0 |
21 | Locked | 38.6 | 52 | 0 |
22 | Locked | 38.6 | 41 | 0 |
23 | Locked | 38.6 | 66 | 0 |
24 | Locked | 38.6 | 35 | 0 |
1 | 46200014 | 43.8 | 5120 | 64 qam | 1 |
2 | 25800000 | 43.8 | 5120 | 64 qam | 4 |
3 | 32600021 | 43.8 | 5120 | 64 qam | 3 |
4 | 39400039 | 43.8 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 02-02-2022 20:03
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | DHSUBsgvca69834ncxv9873254k;f |
SFID | 17507 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 10666 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
31/01/2022 11:39:0 | critical | No Ranging Response received - T3 time-out;CM- |
31/01/2022 11:17:30 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM- |
31/01/2022 11:17:30 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM- |
29/01/2022 10:55:28 | critical | No Ranging Response received - T3 time-out;CM- |
28/01/2022 14:33:25 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM- |
28/01/2022 14:33:25 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM- |
28/01/2022 13:55:41 | notice | LAN login Success;CM- |
01/01/1970 00:01:39 | critical | No Ranging Response received - T3 time-out;CM- |
28/01/2022 13:26:10 | notice | LAN login Success;CM- |
28/01/2022 13:22:43 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM- |
28/01/2022 13:22:43 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM- |
28/01/2022 12:54:19 | notice | SW download Successful - Via Config file |
28/01/2022 12:52:2 | notice | SW Download INIT - Via Config file |
28/01/2022 12:51:52 | Error | Disruption during SW download - Power Failure |
28/01/2022 12:49:12 | notice | SW Download INIT - Via Config file |
28/01/2022 12:49:1 | critical | No Ranging Response received - T3 time-out;CM- |
21/12/2021 15:37:6 | notice | Unit has been restored to factory defaults from a software issued command;CM- |
20/12/2021 16:50:56 | notice | SW download Successful - Via Config file |
20/12/2021 16:45:0 | notice | SW Download INIT - Via Config file |
on 05-02-2022 09:57
Thank you for that information Bradleygraham84.
I have taken a look on our side and I am unable to see any issues.
Can you confirm if you're still having an issue with this?
^Martin
on 05-02-2022 11:25
Hi Martin,
Yes, Ive been having these issues for over a month now and nothing has changed. Its incredibly frustrating as Im getting knowhere with virgin. This is taking a long time to sort out.
Bradley.
on 05-02-2022 12:16
Looks like typical congestion/over-utilisation.
Don’t expect a quick fix anytime soon.
on 06-02-2022 12:02
Just to show that my computer isnt the issue. I went to my mothers house to test the Broadband.
on 08-02-2022 12:51
Hi Bradleygraham84,
Thanks for posting and welcome back to the community!
Sorry for the issue still persisting.
From checking our service I can see you have since contacted our contact centre team.
Has the service improved at all?
Let us know,
on 08-02-2022 14:40
No, nothing has changed at all. I was told to reset the router and that was all.
Bradley.
