  • 97
Theagg
Message 1 of 1
Packet loss and latency in modem mode..
Having mostly solved the speed issues I was having with my Vivid 350 (the technician fitted an attenuator which brought my downstream and upstream power levels back into optimum ranges) I have been running the Hub 3 in modem mode, with a TP Link Archer C7 as the router. (QoS off, Nat Boost on)
However, I'm seeing an awful lot of packet loss and latency spikes since doing that, so any suggestions as to what might be up. The BQM graph here certainly doesn't look as healthy as some I have seen posted on forums here..(this via wired connection) which may explain the occasional speed dips that still plagues me, though nowhere near as bad as before the attenuator was fitted. (For example this dramatic but short lived blip of a speed drop https://www.speedtest.net/result/8262856401)
