Packet loss and intermittent connection issues
airz5
Hi all, Been having intermittent connectivity issues since last Thursday after a 1Gig upgrade. When I go to service status it states there are no problems in my postcode. If I click on the "Test your connection" button it comes back saying "looks like there are issues in your postcode affecting your services".
I'm confused how there can both be no problems in my postcode while also being issues affecting services at my postcode??????
It says there are technicians on the case but not seen any improvements and every time I go back to service status it says no issues in your postcode.
For info it's a Hub 4 in modem mode with a SophosXG FW behind it.
See below BQM as well as power levels etc.
3.0 Downstream channels
26339000000-5.837.4QAM25626
1139000000-1.438.6QAM2561
2147000000-1.738.6QAM2562
3155000000-1.839.0QAM2563
4163000000-2.338.6QAM2564
5171000000-3.138.6QAM2565
6179000000-3.538.6QAM2566
7187000000-3.539.0QAM2567
8195000000-3.738.6QAM2568
9203000000-3.838.6QAM2569
10211000000-3.838.6QAM25610
11219000000-3.939.0QAM25611
12227000000-3.939.0QAM25612
13235000000-3.939.0QAM25613
14243000000-3.938.6QAM25614
15251000000-4.138.6QAM25615
16259000000-4.137.6QAM25616
17267000000-4.337.6QAM25617
18275000000-4.438.6QAM25618
19283000000-4.439.0QAM25619
20291000000-4.337.6QAM25620
21299000000-4.337.6QAM25621
22307000000-4.937.6QAM25622
23315000000-5.137.4QAM25623
24323000000-5.437.4QAM25624
25331000000-5.437.6QAM25625
27347000000-6.036.6QAM25627
28355000000-6.436.6QAM25628
29363000000-6.536.4QAM25629
30371000000-6.536.6QAM25630
31379000000-6.537.4QAM25631
7 REPLIES 7
airz5
ChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors
26Locked37.490
1Locked38.600
2Locked38.600
3Locked39.000
4Locked38.600
5Locked38.600
6Locked38.600
7Locked39.000
8Locked38.600
9Locked38.600
10Locked38.600
11Locked39.000
12Locked39.000
13Locked39.000
14Locked38.600
15Locked38.600
16Locked37.600
17Locked37.600
18Locked38.600
19Locked39.000
20Locked37.600
21Locked37.600
22Locked37.600
23Locked37.400
24Locked37.400
25Locked37.610
27Locked36.6430
28Locked36.61460
29Locked36.41620
30Locked36.61490
31Locked37.4840
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
33964K1880QAM4096424
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
33Locked39-6.731156082937
3.0 Upstream channels
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
14960000051.35120 KSym/sec64QAM1
24310000051.05120 KSym/sec64QAM2
32360000051.35120 KSym/sec16QAM5
43660000051.35120 KSym/sec32QAM3
53010000051.05120 KSym/sec32QAM4
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA001170
4US_TYPE_STDMA0000
5US_TYPE_STDMA0010
3.1 Upstream channels
ChannelChannel Width (MHz)Power (dBmV)FFT TypeModulation
1210.4472KQAM8
ChannelChannel TypeNumber of Active SubcarriersFirst Active Subcarrier (Hz)T3 TimeoutsT4 Timeouts
12OFDMA20853.400
Power and upstream QAM levels all over the place.
It does look like a local outage.
airz5
So I guess the $64,000 dollar question is are they actually looking at it given the conflicting info their service status is telling me?
Reece_MH
Hi airz5,
Thanks for posting, and welcome back to our Community Forums!
I'm sorry to hear you're experiencing issues with your Broadband service. Our Service Status page only shows large wide-scale outages during the first check. When clicking the "Test my connection" button, this checks things down to a property level.
I've taken a look on our side, and can see you're affected by the following, known issue:
Fault Description: SNR (Signal-To-Noise) - You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then
Fault Reference: F010408503
Estimated Fix Time: 26 JAN 2023 18:00
I'm very sorry for any inconvenience caused by this problem and rest assured, we're working as hard as possible to get this resolved.
Cheers,
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
Thanks for that Reece but are there any further updates to this issue? This has been going on for about a month at this point. It would be nice if the status page we have access to gave similar information to the above you posted. All I still get is that there is a fault and technicians are working on it.
disrupted
This is exactly what I have been having for more than a week. At the very same time VM service status page can say one thing (not matching reality), the status check phone line says another thing (contradicting the website), and you can get messages from the app that contradict both.
Then you phone N times, and the so-called fault team person is telling you made-up porkies that contradict all router logs, all BQM graphs collected over days.
Then you get a message that everything is fixed. Then it continues to be atrocious for days and days after that.
I have been doing this cycle now since 30 Jan and getting nowhere... I cannot understand how 2-3 different access methods to the same status check system can tell completely different and nonsensical status when it is disconnecting with sync losses, critical partial service, and bursts of total packet losses on the BQM snapshots.
Thanks for coming back to us airz5, I have looked into this for you and can confirm that there is an SNR issue in your area, this has been logged under reference F010408503 and the current estimated fix time for this is Wednesday 15th February at 1pm.
We are unable to provide any further information about the fault as we don't have access to the more in-depth details of the issues.
I will also pass on your feedback about the service status page to the concerned teams.
Kind Regards,
Steven_L
