  • 9
bbthread
Message 1 of 9
Packet loss, SYNC timing synchronisation failure, RCS partial service, and No ranging response
I am very confused and unhappy with the service I have been receiving from my Virgin Media Vivid 350 package as of late.
I am not sure how long it has been going on but I have been noticing it mainly in the last month. I have now started recording the packet loss and checking the network log of the 3.0 Hub and can confirm at random times I will get anywhere from 5% to 10% packet loss, as well as Synch timing synchronisation failure, RCS partial service and no ranging response notifications on my 3.0 Hub network log.
I have had the 3.0 Hub in modem mode for the last 2 months and before that had it in standard router mode. I have tried both setups and I am recording the same issues regardless of which mode it is in. I work from home and I also like to game in my spare time, this is increasingly becoming a big problem - particularly when gaming.
Is there a known issue with the latest firmware? Or perhaps a problem in my area ME16?
Kind regards
  • 9
bbthread
Message 2 of 9
Re: Packet loss, SYNC timing synchronisation failure, RCS partial service, and No ranging response
Sorry, here is the link to the BQM graph of the last 24 hours. Please ignore the 100% packet loss at the start, this was where I was setting it up and had to change a firewall setting to allow it to work.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1d2b3035c6550b00526e9a2260959d9922...
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/1d2b3035c6550b00526e9a2260959d9922... Broadband Ping[/url]
  • 12.35K
  • 466
  • 1.1K
Message 3 of 9
Are you in modem mode now? And with what own router do you have or is it to a PC?
Do you mostly get Packet loss when downloading or uploading?
As your BQM shows clear then spikes with Packet loss.
Could you post your downstream and upstream from the hub 192.168.100.1
  • 9
bbthread
Message 4 of 9
Hi Alessandro, thanks for the quick reply!
Yes it is in modem mode now. It is linked into a Netgear Nighthawk R7000 router and from there linked directly into my PC. With Cat 5 LAN cables.
The packet loss seems to be random. All I have been doing since my last post half an hour or so ago is watching a twitch live stream - and I just recorded quite a large packet loss spike. I will quite often get the packet loss when playing games too, I don't know if it is linked to that or just a coincidence. This is how I first noticed the problem as my the game has on screen network stats which show packet loss and latency.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1d2b3035c6550b00526e9a2260959d9922032f1d-02-07-2019
Please see downstream and upstream below:
12990000000.540256 qam21
2139000000-0.239256 qam1
3147000000-0.240256 qam2
4155000000040256 qam3
5163000000040256 qam4
61710000000.440256 qam5
71790000000.440256 qam6
81870000000.540256 qam7
91950000000.740256 qam8
102030000000.740256 qam9
112110000000.540256 qam10
122190000000.540256 qam11
132270000000.540256 qam12
142350000000.440256 qam13
152430000000.240256 qam14
16251000000040256 qam15
17259000000040256 qam16
18267000000040256 qam17
19275000000-0.240256 qam18
20283000000-0.240256 qam19
21291000000040256 qam20
223070000000.740256 qam22
233150000000.940256 qam23
243230000001.240256 qam24
1Locked40.352616750
2Locked39.850673966419
3Locked40.313923921023
4Locked40.922837324865
5Locked40.331574149536
6Locked40.34439918128
7Locked40.339338975669
8Locked40.313874719185
9Locked40.3542411679
10Locked40.3289911410
11Locked40.3239910303
12Locked40.3227910096
13Locked40.328499746
14Locked40.927819514
15Locked40.328448905
16Locked40.927969499
17Locked40.926358988
18Locked40.935707470
19Locked40.935238312
20Locked40.338827376
21Locked40.339487878
22Locked40.349736482
23Locked40.364686157
24Locked40.373195804
1602999984.85512064 qam9
2394000074.1512064 qam12
3462000194.65512064 qam11
4537000144.7512064 qam10
3ATDMA0000
4ATDMA000
0
  • 9
bbthread
Message 5 of 9
29/06/2019 10:43:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2019 10:44:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2019 15:41:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2019 07:36:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2019 10:57:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2019 10:58:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2019 19:22:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2019 19:26:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 16:26:21criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 16:33:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 22:56:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 22:59:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 23:45:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2019 23:55:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 09:06:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 09:08:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 11:02:19criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 11:02:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 11:20:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2019 11:21:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12.35K
  • 466
  • 1.1K
Message 6 of 9
Odd you have a big packet loss happen yet logs show nothing for that time 5pm.
  • 9
bbthread
Message 7 of 9
I have just started playing a game online multiplayer and the packet loss has started, it seems to be linked to what I am doing. Any ideas?
  • 9
bbthread
Message 8 of 9
Yes, as soon as I started playing a multiplayer game it is also started having the problem. It lasts for a little while then goes away, intermittently.
Interestingly since we spoke the packet loss has got more regular, but the latency hasn't dropped massively as well. Just the packet loss... As you can see on the graph.
  • 9
bbthread
Message 9 of 9
The problem has been really bad this evening. Any suggestions?
