on 08-09-2021 16:07
Hey, ive been having some problems with my internet the last week and a half not really sure what is wrong as it has been fine before that, im getting constant mini disconnects, packet loss and playing online games is pretty unstable it happens on ethernet and Wifi. I have done many resets over the week and a pinhole reset and the problem still persists. Any help would be appreciated.
on 08-09-2021 16:12
on 08-09-2021 16:18
on 08-09-2021 16:31
yeah i double checked and just rang the number there doesn't appear to be any faults in the area :(.
there isn't much in the network log as i logged in when i pinhole reset, whoops.
hope that's everything you need.
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 267000000 | 275000000 | 283000000 | 291000000 | 299000000 | 307000000 | 315000000 | 323000000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | -4.26 | -4.09 | -4.01 | -4.11 | -4.14 | -3.94 | -3.87 | -4.00 |
RxMER (dB) | 36.84 | 37.09 | 36.84 | 36.84 | 37.64 | 37.09 | 37.09 | 36.84 |
Pre RS Errors | 1021 | 975 | 376 | 375 | 280 | 296 | 279 | 297 |
Post RS Errors | 297 | 303 | 286 | 308 | 280 | 295 | 279 | 296 |
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 4 | 1 | 2 | 3 |
Frequency (Hz) | 39400000 | 60300000 | 53700000 | 46200000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 64QAM | 64QAM | 64QAM | 64QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 49.75 | 50.75 | 50.25 | 49.75 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 5 | 0 | 0 | 0 |
T4 Timeouts | 0 | 0 | 0 | 0 |
First Time | Last Time | Priority | Error Number | Description |
07/09/2021 21:05:17 GMT | 07/09/2021 21:05:17 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
07/09/2021 18:33:01 GMT | 07/09/2021 18:33:01 GMT | Error (4) | 68010302 | DHCP WAN IP |
07/09/2021 18:31:58 GMT | 07/09/2021 18:31:58 GMT | Error (4) | 68000407 | TOD established |
Time Not Established | Time Not Established | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
Time Not Established | Time Not Established | Notice (6) | 84000510 | Downstream Locked Successfully |
07/09/2021 18:29:09 GMT | 07/09/2021 18:29:09 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:35:40 GMT | 07/09/2021 15:35:40 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:15:51 GMT | 07/09/2021 15:15:51 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:15:21 GMT | 07/09/2021 15:15:21 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:01:52 GMT | 07/09/2021 15:01:52 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:01:46 GMT | 07/09/2021 15:01:46 GMT | Warning (5) | 90000200 | CSFR Detect - Expired Content Submitted ; LAN Interface |
07/09/2021 15:01:37 GMT | 07/09/2021 15:01:37 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:01:24 GMT | 07/09/2021 15:01:24 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 15:01:13 GMT | 07/09/2021 15:01:13 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 14:56:41 GMT | 07/09/2021 14:56:41 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
07/09/2021 14:56:35 GMT | 07/09/2021 14:56:35 GMT | Warning (5) | 66050300 | Auth Fail - Web login failed. |
07/09/2021 14:49:06 GMT | 07/09/2021 14:49:06 GMT | Error (4) | 68010302 | DHCP WAN IP |
on 08-09-2021 16:48
on 08-09-2021 16:57
Hey, we just use the SH2 no other routers.
In the back of the hub we have 2 Xbox consoles and 2 Wifi powerline adapters (not sure of the real name for those) as Wifi upstairs in 2 of the rooms is really bad to non existent.
Lewis
on 08-09-2021 19:54
on 08-09-2021 20:04
ok ill give that a go, ill get back to you tomorrow with my findings thanks for the help so far. 🙂
Lewis
on 09-09-2021 13:12
Hey,
I disconnected the ethernet cables as suggested from 8.20pm - 10.20pm last night but there still appears to be some packet loss but not as severe (i also wasn't using it as much in that time) should i still continue with putting the cables in 1 by 1?
Lewis
on 09-09-2021 13:32
