  • 6
hisamsiddiqi
PLEX port forwarding Hub3
Hi Guys
My virgin Kit will arrive in a couple of days , Can i access my PLEX server remotely by activating port forwading on the Hub3 menu as it stands right now as some people mentioned you cant do that on the new router anymore?
Can anyone please give some information
  • 3.65K
  • 201
  • 608
chenks
Community elder
Re: PLEX port forwarding Hub3
yes you can.
just give the plex server a static IP, and set the port forward to point to that IP (port 32400 if i remember correctly).
  • 4.61K
  • 309
  • 770
Roger_Gooner
Superstar
The Plex server's IP address must be fixed, this can be set statically or reserved outside the DHCP range (my preference as it's easier to manage).
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
