steveterry
Message 1 of 11
PC disconnects from internet (Yes me too) Hub 3.0
As with the other posts here my PC is being constantly disconnected from the internet. Pings fail, webpages cannot be resolved (ERR_NAME_NOT_RESOLVED), WIFI equipment cannot connect..  Hub test shows (a brief  example)
9The device has low signal strength, please move it closer to Chromecast.
10The device has low signal strength, please move it closer to Google-Home-Mini.
11The device has low signal strength, please move it closer to ...
The list goes on.......
13Your broadband connection is down.
These items are within 6 feet of the router.
This has being going on for months, I have checked cables reset and reset and reset..So sick of it.
1970-01-01 00:00:24.00 Warning! ToD request sent - No Response received;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-02 14:43:24.00 critical No Ranging Response received - T3 time-out;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:30.00 Warning! Lost MDD Timeout;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:30.00 Warning! MDD message timeout;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-02 15:31:33.00 critical No Ranging Response received - T3 time-out;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.00 Warning! Lost MDD Timeout;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.00 Warning! MDD message timeout;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-02 20:31:40.00 critical No Ranging Response received - T3 time-out;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-06 00:02:04.00 Warning! RCS Partial Service;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-06 00:02:05.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-06 00:02:05.00 Warning! RCS Partial Service;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-06 00:02:10.00 Warning! Lost MDD Timeout;CM-MAC=******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-06 00:05:12.00 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:18:42.00 critical No Ranging Response received - T3 time-out;CM-MAC=******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-08 16:14:07.00 Error DHCP RENEW sent - No response for IPv4;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-08 18:28:25.00 critical No Ranging Response received - T3 time-out;CM-MAC=*******;CMTS-MAC=*******4;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 00:55:49.00 Error DHCP RENEW sent - No response for IPv4;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 09:37:35.00 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 15:33:24.00 critical No Ranging Response received - T3 time-out;CM-MAC=*******;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.0;
12990000001.738256 qam21
24030000001.538256 qam28
33950000001.738256 qam27
43870000001.538256 qam26
53790000001.437256 qam25
63230000001.737256 qam24
73150000001.938256 qam23
83070000001.738256 qam22
92910000001.738256 qam20
102830000001.538256 qam19
112750000001.238256 qam18
122670000001.538256 qam17
132590000001.938256 qam16
14251000000238256 qam15
152430000002.238256 qam14
162350000002.538256 qam13
172270000002.738256 qam12
182190000002.938256 qam11
19211000000338256 qam10
202030000003.238256 qam9
211950000003.538256 qam8
221870000003.738256 qam7
231790000003.738256 qam6
241710000003.938256 qam5
1Locked38.6160
2Locked38.62740
3Locked38.62200
4Locked38.62840
5Locked37.62690
6Locked37.6560
7Locked38.9310
8Locked38.6310
9Locked38.6200
10Locked38.9150
11Locked38.9150
12Locked38.9210
13Locked38.680
14Locked38.9130
15Locked38.6100
16Locked38.670
17Locked38.690
18Locked38.6110
19Locked38.690
20Locked38.6120
21Locked38.980
22Locked38.680
23Locked38.970
24Locked38.6130
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
  • 9.62K
  • 1.01K
  • 1.52K
Message 2 of 11
Re: PC disconnects from internet (Yes me too) Hub 3.0
On wifi or ethernet or both ?
  • 13
skillzpenguin
Message 3 of 11
Looks like lowering the power levels won't fix the same problem for me.
  • 1.78K
  • 99
  • 330
Super solver
Message 4 of 11
You need to post your upstream as well.
steveterry
Message 5 of 11
13020000032.5512064 qam2
22360000032512064 qam3
2ATDMA0010
Disconnects both wired and WIFI
  • 13
skillzpenguin
Message 6 of 11
Does a yellow triangle symbol pop up when it disconnects?
steveterry
Message 7 of 11
On the PC?, Occasionally, depends on how long it goes off for.
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Message 8 of 11
Hi  steveterry,
Your connection looks okay from this end, with both Hub stats and local circuit reporting back in good shape.
Are the drop outs happening just on wireless or are wired connections affected too, is there any change in the Hub lights when connectivity is lost and does this affect all connected devices simultaneously?
Drop us a few more details and we'll be able to assist further.
Kind rgds
Ralph_R
Forum Moderator
steveterry
Message 9 of 11
The drop outs happen on both wireless and cabled. I have now connected in modem mode and this has stopped the WIFI disconnects so clearly it is a problem with the Hub 3 router. The wired connection still drops.
  • 12.64K
  • 483
  • 1.13K
Message 10 of 11
Hows your connection in modem mode by wire?
