on 13-07-2022 11:21
We have had intermittent connection to Wi-Fi since getting virgin in March but it is particularly bad now. We have done all the things suggested but has not fixed the issue. We believe the hub 3.0 is faulty and would like to request a new one. There are a number of posts on the forum reporting the same issue, our light has never been white always an amber as with many other people having the same problem. Virgin please fix this for us.
on 13-07-2022 13:03
on 13-07-2022 19:44
I have done the pin reset, light is still amber and will reply tomorrow to see if this has improved things.
on 14-07-2022 22:30
Hi John,
I am still having problems with Wi-Fi dropping after pin reset. Light was flashing green on Wi-Fi symbol light when outage occurs.
on 15-07-2022 13:56
on 17-07-2022 15:22
Hey there @Julial, thanks for reaching out to us.
I am sorry to hear about the broadband issues you're having recently.
I have had a look on the system and cannot see any issues appearing on my end.
Can I ask if you've tried the above advice given by @jbrennand ?
Let us know and we can go on from there.
Kind regards.
on 18-07-2022 14:07
Hi IIyas,
Thank you for responding, yes we have tried pin reset and checked for interference even bought extension cable to move hub into hall but hasn’t made any difference. We have had virgin before and worked like a dream which is the reason we switched back. We knew internet connection is good it is just Wi-Fi that the issues remain. Wi-Fi is dropping out all the time my daughter cannot get a good enough signal to use her tv. We are convinced this issue is to do with a faulty hub please send us a new one and if it makes no difference then we will send it back to you. My husband works from home so needs a quick solution. We had no problems last time we used virgin the only thing that has changed is the hub.
18-07-2022 15:57 - edited 18-07-2022 16:01
When you say you moved your Hub, what co-ax cable did you use?
The real solution to this issue (if it is wifi only) is not to keep swapping Hubs (they are all not great with wifi) but to use ethernet cable connections wherever possible (running cable is easier than you think) or just put any VM Hub into modem mode and improve your wifi with something like these (or better)...
https://www.amazon.co.uk/Archer-C6-Wireless-Supports-Parental/dp/B07L5YRYF4/
https://www.amazon.co.uk/Deco-M4-Seamless-Coverage-Replacement/dp/B07NH1J543/
on 18-07-2022 21:13
Still major problems with hub 3, we have no Ethernet connections other than Hive and Philips hue. We have no tv box as just want internet and phone service. If I go up stairs and run a speed test first reading was <1mbps then did it again and it was 100mpbs and this is what happens all the time. We have never had issues before and have same kit connected we did before. This is without doubt a failed Hub. Can someone at Virgin please resolve this issue.
on 21-07-2022 08:45
Hi @Julial
Sorry to hear that your still having this ongoing issue. Are you able to remove the coaxial cable you have purchased and installed and move the router back to how it was set up previously. We would not be able to support if you have used any of your own cabling or 3rd party equipment.
Once you have moved the router back to how it was originally installed by the engineer, can you try a 60 second pin hole reset on the router. This will revert any customisations back to factory settings and full update the router with firmware/software updates. Please do not reboot the router whilst it is completing the pin hole request.
Please then setup a Broadband Quality Monitor and post a link to your live graph. Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum. Once we have this extra information we will be able to offer you the further support you need!
