on 22-09-2022 22:09
Newly installed Hub 3 early last week and the signal strength in the rooms directly next to the hub are fine but any rooms not directly next to the hub (in a standard sized house) have weak to no signal. In the kitchen it drops out complete despite being within a at max 10m displacement to the hub.
The router itself also seems to be running slightly warm and has an amber light instead of white/green
on 25-09-2022 13:06
Hey @Honeywood,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your hub at the moment.
Please could you perform a pin hole reset of your hub and let me know if this helps to resolve the issues at all.
Regards,
Steven_L
