on 06-08-2021 11:18
Hi, I recently got Virgin installed (last week) and as soon as the technician left the bottom hub light turned orange (definitely orange). No other lights show any colour. After restarting and resetting it stays orange (after a few seconds of being green.
My internet keeps dropping (on all devices) and the speed sometimes drops to slow too.
I can't see an explanation for the orange colour in any of the help sections.
Any help would be appreciated.
on 06-08-2021 14:33
on 06-08-2021 16:27
Hi @completewin,
Thank you for your posts and welcome to our community forums. We're here to help.
I'm very sorry to hear about this. Is your connection being impacted at all, or is it just the light turning orange that's a little concerning?
In regards to the temperature, you're saying it's not hot to the touch? We'd expect there to be a little bit of heat if you touch it just to the electric current that goes through it, but it shouldn't anything beyond lukewarm really. I'd also make sure it's in a on open space where it gets plenty of ventilation if it isn't already.
on 06-08-2021 17:07
Like I said "My internet keeps dropping (on all devices) and the speed sometimes drops to slow too."
But I wouldn't say it's too hot, probably normal warmth.
on 06-08-2021 17:32
Hi @completewin,
Thank you for clarifying. Would you mind confirming any other diagnostics and troubleshooting you've done thus far in an effort to remedy this?
on 08-08-2021 11:37
Sorry about the late reply, I've turned it off at the plug for at least 10 minutes multiple times (it always takes a good 10 minutes to comeback onm and work again) and I've done a full factory reset but the preoblems still persist.
on 09-08-2021 20:56
Wondering if I could get any help with this please? WiFi still dropping continuously on all devices.
on 10-08-2021 08:10
Sounds like a new hub required - especially if connections are dropping all the time!
on 10-08-2021 10:42
Could be. How do I go about getting this sorted?
on 10-08-2021 10:44
You could call it in on 150:
It'll ask you to reboot the hub (as you already have done - don't)
You will then be cut off
Wait a couple of minutes
Call 150 again - report a broadband fault - The system will recognise that you called before and transfer you to a person!
Or wait for forum staff - could be a day or so!
