  • 23
c_e
Message 1 of 13
Opted out of Virgin Media WiFi - Still broadcasting SSID
I opted out of this a long time ago (probably around a year ago) but my super hub 2ac still broadcasts a 'Virgin Media' SSID with what looks like a RADIUS username/password needed to authenticate. How to I get this SSID to stop broadcasting? Is the opt out form on the website broken? Thanks
  • 15.66K
  • 1.63K
  • 3.52K
Message 2 of 13
Re: Opted out of Virgin Media WiFi - Still broadcasting SSID
Are you sure it’s you and not your next door neighbour?
  • 12.18K
  • 456
  • 1.09K
Message 3 of 13
You could use modem mode and get your own wireless router that would opt you out VM wifi.
  • 23
c_e
Message 4 of 13
Yes, I'm sure it's mine as the VM SSID MAC address & signal strength are the same as my primary SSID. Others do appear but those are broadcast from devices made by arris and not netgear (manufacturer of the superhub 2ac)
  • 7.97K
  • 823
  • 1.23K
Message 5 of 13
You got any powerline wifi adapters plugged it that may still be broadcasting on that ssid ?
  • 15.66K
  • 1.63K
  • 3.52K
Message 6 of 13
Have you checked the status of your opt in/out in the My Profile section of My Virginmedia?
  • 15.66K
  • 1.63K
  • 3.52K
Message 7 of 13
You can also check in the Virgin Media Connect app Settings:
  • 23
c_e
Message 8 of 13
No powerlines or anything along that line. The only thing that broadcasts wireless networks is the superhub.
  • 23
c_e
Message 9 of 13
That was one of the things I checked first - It is set to opt out (and has been for a long time)...
  • 13.17K
  • 1.66K
  • 3.72K
Shelke
Message 10 of 13
Turn the hub off, does it stop listing as available in the WiFi list?
Have you pin hole reset the hub yet?
