  • 4.06K
  • 481
  • 1.31K
Message 11 of 27
Re: Not acheiving 500mbs
In that case it suggests to me either something on the PC (BIOS or software) is throttling your speed at 200Mbps or the Hub has a fault with it's Ethernet ports.
I can't recall ever hearing about a faulty Hub limiting Ethernet speeds to 200Mbps, but I suppose it is possible.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Click to learn more about VIP
Use Kudos to say thanks
  • 4.06K
  • 481
  • 1.31K
Message 12 of 27
Just seen your hub stats and power levels look OK.  The "RCS Partial Service" errors could be an issue, but as @Rachael_F has carried out checks on the VM back end and found nothing they may have been a temporary glitch.
Scott
  • 26
Nkawecki
Message 13 of 27
I have also tried 2 laptops and get the same fluctuating speeds. Seems strange how the download speeds fluctuate but the upload remains constant at 37
Oh and  not sure if I mentioned but my wifi is good with speeds over 300??
  • 4.06K
  • 481
  • 1.31K
Message 14 of 27
Well that looks to me like an issue with the Ethernet ports on the Hub.  Hopefully @Rachael_F or one of her colleagues will get back to this thread tomorrow and be able to arrange a new hub for you.
Scott
  • 26
Nkawecki
Message 15 of 27
I dont suppose it matters which port I am plugged into on the hub?
  • 4.06K
  • 481
  • 1.31K
Message 16 of 27
It shouldn't, but worth giving them all a try to see if it is just an individual port fault.
Scott
  • 26
Nkawecki
Message 17 of 27
So tested all 4 ports this morning with nothing else connected to the HUB. See results below for Download speeds, Upload was constant at 37 on ALL ports:
Port 1 - 78
Port 2 - 98
Port 3 - 121 (now left connected to PC)
Port 4 -106
All test were run in the space of 5 minutes.
  • 1.65K
  • 92
  • 166
Message 18 of 27
Cheers so much for popping back @Nkawecki
We do appreciate all the checks you have done - as our VIP @SCA1972 has advised, I think a new Hub would be the way to go; it sounds like there may be an issue with the ports on the Hub as we've checked everything else.
I'll pop you a Private Message so we can go through security and get one booked out for you.
Just look out for the Purple Envelope and pop us a reply when you can.
Cheers
Katie - Forum Team
  • 26
Nkawecki
Message 19 of 27
Reply sent thanks Kaite
  • 26
Nkawecki
Message 20 of 27
Hi Katie
Did you get my P{M yesatrday morning? Still no had a response on when the new hub will be sent?
