  • 26
Nkawecki
Message 1 of 27
Not acheiving 500mbs
So I have been with virgin for 3 weeks with a 500mb package and at best I only get 200mb with a wired CAT 6 connection.
I have spent numerous hours on the phone trying to resolve and now Virgin think there is a compatibility issue with my network adaptor on my Lenovo PC fitted  with a Realtek LAN adaptor 802.11ac PCI-E NIC.
Strangely the download speed fluctuates between 80mb and 200mb but upload stays constant at 37mb.
When doing a speed test on my Samsung note 9 over WiFi i get 280mb!
Any ideas? Issues with the HUB 3?
  • 1.26K
  • 190
  • 284
DJ_Shadow1966
Knows their stuff
Message 2 of 27
Re: Not acheiving 500mbs
Hello
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
  • 1.15K
  • 66
  • 210
Message 3 of 27
Hi Nkawecki,
Thank you for reaching out with your broadband concerns. I'm really sorry that you're not getting expected speeds.
I've had a look at the backend of your services and the local network, but have been unable to identify anything which would explain this issue. Everything's reporting within spec and all our tools suggest your connection should be fine.
It would help if you're able to run a few more diagnostic tests from your end so we can rule out certain aspects. First of all, I'd just like to check what you're using to test your speeds? We'd usually recommend speedtest.net as they're accurate and impartial.
Could you start by putting your hub into modem mode to see if you get different speed test results? This would establish whether the problem lies on the router side of things.
Could you then put your PC into safe mode and run further tests? This helps to rule out any conflicting settings on your device.
Rachael
  • 26
Nkawecki
Message 4 of 27
Yes always use Speedtest.net for all my tests.
I have ran the hub in Modem Mode and no improvements. 113Mbps Down, 37Mbps Up
I have also put my PC into safe mode and only a slight improvement? 172Mbps Down, 37Mbps Up
  • 26
Nkawecki
Message 5 of 27
Hi There
Thanks for the response and had put my HUB into Modem Mode as advised by the moderator but now I can't log into my HUB at all. have tried http://192.168.0.1 and no joy!!!!?????? Ill try a reboot.
  • 9.46K
  • 980
  • 1.49K
Message 6 of 27
In modem mode its... http://192.168.100.1/
  • 26
Nkawecki
Message 7 of 27
Thanks back in
  • 4.06K
  • 481
  • 1.31K
Message 8 of 27
Have tried a different Ethernet cable to rule that out? I'd also check the Ethernet adapter drivers you have installed and see if they are up to date and check the driver release notes for any known issues.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Click to learn more about VIP
Use Kudos to say thanks
  • 26
Nkawecki
Message 9 of 27
I bought a CAT 7 cable this weekend and also bought a i Gigabit USB Adapater to rule out cable and network card. Have installe and no improvements.
Linksys USB 3.0 Gigabit Ethernet Adapter
https://www.amazon.co.uk/gp/product/B00QSHHWI2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
UGREEN Ethernet Cable, Cat 7 Gigabit Lan Network RJ45 High-Speed Patch Cord Flat Design 10Gbps for 600Mhz/s https://www.amazon.co.uk/gp/product/B00QV1F19C/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
  • 26
Nkawecki
Message 10 of 27
Info as requested
Cable Modem Status
Item
Status
Comments
347000000
Locked
Ranged Upstream Channel (Hz)
39399983
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
347000000
7
40
256 qam
25
2
219000000
7.4
40
256 qam
11
3
227000000
7.4
38
256 qam
12
4
235000000
7.3
38
256 qam
13
5
243000000
7
38
256 qam
14
6
251000000
6.9
40
256 qam
15
7
259000000
6.6
38
256 qam
16
8
267000000
6.5
38
256 qam
17
9
275000000
6.3
38
256 qam
18
10
283000000
6
38
256 qam
19
11
291000000
5.6
38
256 qam
20
12
299000000
7.3
38
256 qam
21
13
307000000
7.5
38
256 qam
22
14
315000000
7.5
38
256 qam
23
15
323000000
7.5
38
256 qam
24
16
355000000
7
38
256 qam
26
17
363000000
6.9
38
256 qam
27
18
371000000
7
38
256 qam
28
19
379000000
7
38
256 qam
29
20
387000000
6.8
38
256 qam
30
21
395000000
6.9
38
256 qam
31
22
403000000
6.6
38
256 qam
32
23
411000000
6.4
38
256 qam
33
24
419000000
5.9
38
256 qam
34
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
0
0
2
Locked
40.3
4
0
3
Locked
38.9
6
0
4
Locked
38.9
5
0
5
Locked
38.9
4
0
6
Locked
40.3
6
0
7
Locked
38.9
6
0
8
Locked
38.9
6
0
9
Locked
38.9
4
0
10
Locked
38.9
4
0
11
Locked
38.9
13
0
12
Locked
38.6
5
0
13
Locked
38.9
4
0
14
Locked
38.9
4
0
15
Locked
38.9
1
0
16
Locked
38.9
5
0
17
Locked
38.9
5
0
18
Locked
38.9
6
0
19
Locked
38.9
4
0
20
Locked
38.9
4
0
21
Locked
38.9
5
0
22
Locked
38.9
17
0
23
Locked
38.9
6
0
24
Locked
38.6
6
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39399983
4.05
5120
64 qam
2
2
25799998
4.05
5120
64 qam
4
3
32599998
4.05
5120
64 qam
3
4
46200017
4.05
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
,.iyewrkldJKDHSUBsgvca69834ncxv987
SFID
32672
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
816
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Time
Priority
Description
08/11/2019 15:11:33
notice
SW Download INIT - Via Config file
08/11/2019 15:14:15
Error
Disruption during SW download - Power Failure
08/11/2019 15:14:26
notice
08/11/2019 15:16:52
notice
SW download Successful - Via Config file
08/11/2019 19:08:50
critical
27/11/2019 10:48:17
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 10:48:19
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 10:48:20
Warning!
27/11/2019 10:48:22
critical
27/11/2019 10:48:23
Warning!
27/11/2019 10:48:23
critical
27/11/2019 10:48:25
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2019 05:51:24
critical
