on 27-01-2022 08:26
Hi I had no wifi for 48 hours none on tv as connected wired I reset hub at the back switched off and on etc then yesterday my tv come on for my Netflix etc but no wifi at all it’s finding my wifi ssid used password from under modem and won’t connect at all also says this when my fighter tried to connect off her mobile any help be great can’t get technician out till Monday !!!
on 27-01-2022 09:12
If you’ve got an engineer booked you’ll need to wait until they arrive
on 27-01-2022 15:33
on 02-02-2022 14:55
Welcome to our Community Help Forum 🙂
Thank you for maing this post regarding your connection, sorry to hear you've been experiencing WiFi issues. I understand this must be frustrating. I have checked our systems and can see you missed the engineer appointment on Monday. How is everything working for you now?
Kind regards,
Serena
on 02-02-2022 14:57
Hello I didn’t miss the engineer Monday because the wifi suddenly came back on Sunday after being of 5 days so I went online to canel the appointment and it said I didn’t have one which I found strange
on 02-02-2022 15:05
VM probably identified an area fault that they then fixed. When an area fault is discovered all technicians visits are cancelled, unfortunately they do not advise you.
