Jaxjones75
Message 1 of 10
No connection to devices
So all of my devices won’t connect to my hub
i called Tuesday and they said their was issues .
i was told it would be the 9th before it’s fixed .
ive done the usual reset , but it won’t except the hub password .
but after speaking to a neighbour they don’t have any issues ?
I was told it was an area issue ?
Can anyone throw and light on the issue ?
  • 224
  • 32
  • 37
Shweby
Superfast
Message 2 of 10
Re: No connection to devices
Sounds like an issue with your hub, and your hub only. Are you able to connect via ethernet, ie a laptop or pc?
______________________________________
I work for Virgin Media, but all opinions are my own.
Jaxjones75
Message 3 of 10
I’m going to give it a go now .
Jaxjones75
Message 4 of 10
So I’ve tried using the Ethernet connection through my laptop
still no joy
  • 7.28K
  • 759
  • 1.14K
Legend
Message 5 of 10
Have you tried a pinhole reset to factory yet ?
  • 224
  • 32
  • 37
Shweby
Superfast
Message 6 of 10
In that case it sounds like your hub has failed. Or you have lost signal down your line. But as your devices wont accept the wifi password, it sounds like its the hub. You will need to phone for an engineer, or wait about 1 week for a mod to respond. What hub do you have? SH1/2/2ac/3? As just mentioned, try a pinhole reset.
Jaxjones75
Message 7 of 10
@Shweby
I’ve got the 3
ive only had it a month as the last one wouldn’t turn on .
ive done the reset also
ill call again Tomorrow
JEvans64
Just joined
Message 8 of 10
I have exactly the same problem. When I call a recorded message says there is a ‘complex’ issue in my area.  Spoke to someone and they told me would be fixed 9th Oct.  When I sign into my account there shows no problems with my service. My hubs shows just the white light on the base I have also done the pinhole reset on the back of the hub. I can get nothing at all - will not accept password.
  • 11.7K
  • 347
  • 677
Forum Team (Retired) Samantha_L
Message 9 of 10
Hi Jaxjones75,
Sorry to read you are having an issue with the broadband connection.
When I checked your line, the router is showing as online with devices connected.
Has anything changed since you posted? Is the internet working ok?
Sam
  • 7.28K
  • 759
  • 1.14K
Legend
Message 10 of 10
try this if you haven't - a pinhole reset with a twist - as per message 12 - has helped a lot of people this week.
https://community.virginmedia.com/t5/Networking-and-WiFi/Newish-hub-3-WIFI-incorrect-password/td-p/3...
