Another option is to do what my lad did....
__________________________________
He is a serious internet gamer who thinks wifi is the work of Satan and should never be used for gaming. Ethernet cabling your devices is always the best way to go, but running cable to his room was problematic.
So he uses a pair of Solwise AC1200 powerline adapters. His PC/Xbox/PS3 can now all be "wired" - with short Cat6 cables – back to the wireless router downstairs and he gets a solid 60-70Mbps on our V200 package - he hasn't complained once in years!
Worth considering whether that will work for your house on your mains circuits, the two circuits must go through the same consumer unit/fuse box (most do) and be free of any "noise". You can also add a wifi access point alongside to boost that up there as well. Or some PA’s have built in wifi too.
Note unless they have GB ethernet ports then speeds will always Max out at below 100mbps - but that shouldn't matter too much for gaming. Or is he streaming at 4K from Netflix?
