Stacey7
No WiFi connection anymore on my iPhone 6s
I can no longer connect to my WiFi from my iPhone 6s I have tried everything but it keeps saying incorrect password. The password is correct as all other devices are connected please help.
  • 843
  • 119
  • 181
DJ_Shadow1966
Well-informed
Re: No WiFi connection anymore on my iPhone 6s
Hello
Try the following :-
  1. Touch Settings.
  2. Scroll to and touch General.
  3. Scroll to and touch Reset.
  4. Touch Reset Network Settings.
  5. Touch Reset Network Settings.
  6. The iPhone will reboot. Once it turns on, the default network settings will be restored.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
Stacey7
I’ve tried that but still not worked I’ve rebooted WiFi, the phone the network settings turned WiFi on and off turned Bluetooth on and off turned airplane mode on and off I’ve disconnected the WiFi and tried to rejoin network I’ve tried everything that google has suggested but nothing works in still keeps saying incorrect password. My phone connects to WiFi networks in other places just not my home although up until now it has always connected at home I’m not sure what else to do.
  • 843
  • 119
  • 181
DJ_Shadow1966
Well-informed
Hello
Next option would be to turn of the hub for a few minutes and then turn on, check again if connects to wireless.
Mike
39 years in IT.
Stacey7
unfortunately I have tried that too on many occasions but still nothing I’ve also updated my phone twice ( but had to use someone else’s WiFi) to see if that resolved it but still nothing I’m confused lol
stacey
  • 439
  • 28
  • 42
Hi Stacey7
Thanks for posting. Sorry to hear you're having issues trying to get your IPhone 6s to connect to your Wifi.
Have you tried a pin hole reset on your router at all? This may be the other option to try.
We do have to advise once you have done a pin hole reset you will need to connect all your devices back to your router.
Follow the instructions here to perform the pin hole reset on your hub.
Kind regards Jodi
