on 06-06-2023 19:47
Strange one! My wifi & ethernet are working perfectly aswell as the blue lights (wps) and red light (connection issues) but my hub is just in darkness?? Does that mean a bulb has blown? Ive checked my settings and the brightness is set to 100%! Any ideas? Not the end of the world just annoying.
on 09-06-2023 10:39
Hi Smurf1990
Thank you for your post and welcome to our community.
A dimmed white light is normal and means everything is working okay.
Its difficult to see from the picture, is the light dimmed or not on at all?
Please pop back to us when you can.
Vikki - Forum Team
on 09-06-2023 10:41
The white light doesn't work at all. Ive reset, unplugged it all and still nothing.
on 11-06-2023 12:30
Hi @Smurf1990 thanks for getting back to us.
Sorry that there's no white light showing on your hub still. As this is bothering you, I would like to help you resolve the issue. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
