on 25-11-2022 16:43
Last Thursday (07/11/2022) we upgraded to 1GVolt, and part of the package was un upgrade to Hub 5 from Hub3.
Since then, we have had numerous problems most of which have been solved by giving the 2.4g and 5g networks separate SSID names. However, after running the Connect app, I have noticed that most of the upstairs rooms have weak or no signal.
Living room : 85Mbps Download : 52Mbps Upload
Hallway : 41Mbps Download : 38Mbps Upload
Bedroom : 1Mbps Download : 10Mbps Upload
Bedroom 2 : No signal
Hobby room : Intermittent signal
Would ordering a WIFI Pod help with my problem?
Answered! Go to Answer
on 25-11-2022 16:47
on 25-11-2022 16:47
on 25-11-2022 18:59
Problem on the way to being solved. A WiFi Pod should arrive on Tuesday the 29th.
on 25-11-2022 23:19
Hi @sjane366
With the pod(s) you should be aware of the following requirements for them to work with the Hubs.
The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'
Channel Optimisation must be left on
The SSIDs must be the same and broadcast enabled
The SSID must be password protected
The Passphrases of the SSIDs must match
As long as all of the above points are all met then the Pods will automatically connect to your Hub's WiFi and begin broadcasting. The wireless details from the Pods will be the same as the Hub's details, so no additional steps are required to connect up the devices in the home.
on 28-11-2022 09:10
Hi sjane366,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
We're sorry to hear the WiFi connection is a little erratic. We're glad you have a pod on it's way out to you to try but as mentioned by newapollo, there are some criteria in order for the pods to work.
As you've mentioned you've split the bands, you'll need to revert these back to default. You can find further help on setting up the WiFi Pod here.
Keep us posted on how things go.
