on 12-05-2022 20:51
After I log in to the settings page there does not appear to be an option to select Modem Mode?
on 12-05-2022 20:58
Do you, by any chance, happen to be in the Republic of Ireland?
on 12-05-2022 21:05
Yes….
12-05-2022 21:52 - edited 12-05-2022 21:52
This board is for UK residential users only. You want VM Ireland.
on 12-05-2022 21:58
@Schmicko although @Tudor is correct in that the staff here won’t be able to help you directly, I can tell you exactly what the issue is. By default the VM provision in Ireland provides an IPv6 address and uses a technology called CGNAT, which without going into the details makes it impossible to use modem mode.
But what you can do is to call VM there are ask to be moved to an IPv4 provision, now assuming that they do it without too much fuss, your hub will reboot itself and when it comes up, the modem mode option will be back. What you will lose is the IPv6 addresses, but that’s probably not too much of an issue.
on 13-05-2022 10:51
Ah - Apologies and also thanks for the steer!
on 15-05-2022 13:26
Hi Schmicko
Thanks to both Tudor and also jem101 for advising on this.
We can't get involved here but here are all the contact methods you need;
Their contact us page - https://www.virginmedia.ie/contact/
Twitter - @virginmediaIE
Best.
