on 24-08-2022 21:08
Had a red light on my new hub .. got a replacement .. and still a red light .. internet was fine ( new house ) for the last week and it just went and wont come back on
Any help would be great
on 24-08-2022 21:12
What Hub model is it?
You said internet was fine and now its just gone - so can you check for any “known network faults”
1) Try the “check service,”Area status webpage" (link at top right of this forum) if you can (tether your phone?)
2) Then also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
on 24-08-2022 21:24
Its a hub 2.0
Ive checked the area . All ok
Ive unplugged , rebooted , restarted, reset, disconnected all cables and virgin have confirmed whatever ping they sent is all ok
So at a complete loss
on 25-08-2022 13:33
You sure its an SH2? I have one never seen a red light - see its Sticker below - is yours the same?
It sounds more like a Hub3.
Have you called it in as faulty - what did they say?
