on 25-12-2021 09:42
Hi All,
Pretty much what the title says, issues since installing the new hub this week
Connection will cease but box will stay solid white. Turning it off and on again resets the connection and I'll get it back but it will go off again. Time it takes to go off again varies from an hour to maybe 3 hours but it's been this way since Thursday afternoon
Anyone experiencing similar?
Absolutely no issues with previous hub and all wires are present and correct
Cheers
on 25-12-2021 11:02
not much help here until next week - check coax again and try a reboot - id=f that does not help try a full reset - hold the button a good 30 sec - i understand the reset button is hidden and is underneath somewhere
