12-04-2022 20:05 - edited 12-04-2022 20:09
Finally got these people to send out a tech and replace the router that had been broken since they mailed it out to me, 2 years ago.
It has made no difference.
Various things below. Input welcome.
1 331000000 3 38 256 qam 25
2 203000000 5.5 38 256 qam 9
3 211000000 5.5 38 256 qam 10
4 219000000 5 38 256 qam 11
5 227000000 4.8 38 256 qam 12
6 235000000 4.5 38 256 qam 13
7 243000000 3.9 38 256 qam 14
8 251000000 3.7 38 256 qam 15
9 259000000 4 38 256 qam 16
10 267000000 3.7 38 256 qam 17
11 275000000 3.5 38 256 qam 18
12 283000000 3.5 38 256 qam 19
13 291000000 3.2 38 256 qam 20
14 299000000 2.5 37 256 qam 21
15 307000000 2.7 38 256 qam 22
16 315000000 3 38 256 qam 23
17 323000000 2.7 38 256 qam 24
18 339000000 2.7 37 256 qam 26
19 347000000 2.2 38 256 qam 27
20 355000000 2 38 256 qam 28
21 363000000 2.7 38 256 qam 29
22 371000000 2.9 38 256 qam 30
23 379000000 2.9 38 256 qam 31
24 387000000 2.7 38 256 qam 32
1 Locked 38.6 10 0
2 Locked 38.6 8 0
3 Locked 38.6 10 0
4 Locked 38.6 13 0
5 Locked 38.9 16 0
6 Locked 38.6 8 0
7 Locked 38.6 15 0
8 Locked 38.6 15 0
9 Locked 38.6 11 0
10 Locked 38.9 16 0
11 Locked 38.6 11 0
12 Locked 38.6 10 0
13 Locked 38.6 12 0
14 Locked 37.6 9 0
15 Locked 38.9 15 0
16 Locked 38.6 8 0
17 Locked 38.6 11 0
18 Locked 37.3 15 0
19 Locked 38.6 16 0
20 Locked 38.6 12 0
21 Locked 38.6 15 0
22 Locked 38.6 14 0
23 Locked 38.9 13 0
24 Locked 38.9 3 0
04/04/2022 11:10:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2022 03:29:38 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2022 03:29:38 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2022 00:46:31 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 15:29:38 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 15:29:38 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 14:29:37 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 14:29:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 14:10:6 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2022 17:53:22 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2022 17:08:23 critical TLV-11 - Failed to set duplicate elements;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2022 16:02:56 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2022 21:42:38 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2022 14:58:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2022 09:42:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/01/2022 07:20:53 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2022 04:43:4 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2022 07:51:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2022 07:43:59 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2022 07:43:57 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 13-04-2022 10:53
Hi @HCA
Thanks for posting on our community forum!
I'm going to drop you a private message now to investigate further, please keep an eye on your inbox.
13-04-2022 11:01 - edited 13-04-2022 11:04
Well, damn decent of you all to allow this post to appear, more than 24 hours after I actually posted it.
Any particular reason I am being so heavily screened?
on 13-04-2022 11:07
As it stands, this service is unusable. Utterly.
Just looking at the monitor will show you that. Any attempt to stream content of any kind is a total non-starter, as the line is so screwed, nothing is getting through. My Netflix, Amazon and GeForce NOW subs are all empty money, as I can use none of them
on 13-04-2022 12:56
Hi @HCA
Thanks for the reply and confirming the details
I'm going to drop the area field manager an email to see where we can take this from here / to advise on the next best step as you have already had a tech visit to replace the Hub. I'll be sure to keep you updated with any replies.
on 13-04-2022 13:02
I guess we shall see, then...
