ashleybrown1978
Message 1 of 5
New Custommer with Connection issues - Daily drop out with ' No Ranging Request T3 critical '
Getting pretty fed up as a new customer with constant drop outs and people not able to connect in the home.
Daily, I get drop outs and have to turn off wifi on my phone or computer and wait a minute and then back in as everything just stops working. I put up with it for a bit but have been a customer for a about 3 months and decided enough is enough.
Hub 3.0
I have rebooted the router several times.
Its got the intelligent wifi update
I had a speed boost given me also.
The coverage App tells me everything is great all over the house.
Not sure whats going on really ? Would appreciate any insight or help.
Latest logs are below for moderator / help troubleshooting.
07/05/2019 10:05:18ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2019 10:34:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2019 23:19:15ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2019 05:34:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2019 05:56:13ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2019 12:33:15ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2019 12:33:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2019 22:53:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2019 04:53:42ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2019 04:59:21ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2019 04:59:21noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2019 10:19:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2019 04:56:25ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2019 20:48:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 00:33:59ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 03:24:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 03:50:15ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 07:06:34ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 07:06:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2019 11:08:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
ashleybrown1978
Message 2 of 5
Re: New Custommer with Connection issues - Daily drop out with ' No Ranging Request T3 critical '
11630000000.438256 qam4
21390000000.236256 qam1
31470000000.238256 qam2
41550000000.238256 qam3
51710000000.537256 qam5
61790000000.537256 qam6
71870000000.737256 qam7
81950000000.537256 qam8
92030000000.537256 qam9
102110000000.238256 qam10
112190000000.238256 qam11
122270000000.438256 qam12
132350000000.238256 qam13
142430000000.238256 qam14
152510000000.438256 qam15
162590000000.240256 qam16
172670000000.238256 qam17
18275000000038256 qam18
19283000000038256 qam19
202910000000.238256 qam20
212990000000.240256 qam21
223070000000.240256 qam22
233150000000.238256 qam23
24323000000038256 qam24
1Locked38.64360
2Locked36.65610
3Locked38.63680
4Locked38.65350
5Locked37.34310
6Locked37.369430
7Locked37.35550
8Locked37.63750
9Locked37.64000
10Locked38.63240
11Locked38.92610
12Locked38.92920
13Locked38.63470
14Locked38.64250
15Locked38.63590
16Locked40.93780
17Locked38.93160
18Locked38.65070
19Locked38.64250
20Locked38.93800
21Locked40.37430
22Locked40.96870
23Locked38.97560
24Locked38.97810
1258000003.55512064 qam12
2326000003.5512064 qam11
3394000003.5512064 qam10
4462000613.55512064 qam9
  • 2.17K
  • 121
  • 264
Message 3 of 5
Hello ashleybrown1978
First of all thanks for your post and including the information we needed to ask
I have had a quick look at Hub levels from here and it will need an engineer to come out
I will send you a private message to pass security
Then we can look at when is best to get an engineer booked out
Just check the purple envelope top right of your screen
Gareth_L
ashleybrown1978
Message 4 of 5
Thank you for the response. I thought it might be the case.
I shall reply to you now
Ashley
  • 2.17K
  • 121
  • 264
Message 5 of 5
Thanks for your time today ashleybrown1978
If you can let us know how the visit goes next week, that would be great
Gareth_L
