on 14-07-2021 13:10
Had a quick look at my logs….. noticed these recently…. Problems?
11/07/2021 23:21:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/07/2021 23:11:15 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/07/2021 14:45:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/07/2021 14:24:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 18-07-2021 10:08
AFAIK the WiFi SSID needs to be the same for both bands and Smart Optimisation needs to be on. The Pods will not work otherwise?
on 18-07-2021 10:10
Thank you for coming back to me @TALON1967
Please could you return the hub into the factory settings so that the pod can attempt to use the intelligent WiFi. I have the same issue within my property with the bands being split it really struggled to optimise the WiFi.
Kind regards,
Zak_M
on 22-07-2021 09:57
@Zak_M
why on earth would I want to run in 2.4 ghz mode? I won’t be able to get the higher speeds without using 5ghz.
on 22-07-2021 10:55
Hello TALON1973
I know its the infamous reply to fix things
But can you please reboot the Hub as its showing as being online for over 40 days
Gareth_L
