on 23-08-2022 10:46
Hi there,
I am having issues with my network where I lose connection quite regularly on video calls. It's particularly bad when my wife is also on a video call. Here is the info from the router. I notice that I have some Post RS errors, which I take to be bad, but would appreciate some input. I've tried to escalate this but customer service aren't helping. The constant advice of reboot and try again ad pinhole resets isn't working.
Do these numbers warrant an engineer visit or some further support? Or should I just look for a better router?
Thanks in advance,
1 | 363000000 | 2.2 | 37 | 256 qam | 29 |
2 | 203000000 | 6.3 | 37 | 256 qam | 9 |
3 | 211000000 | 6.3 | 37 | 256 qam | 10 |
4 | 219000000 | 5.9 | 37 | 256 qam | 11 |
5 | 227000000 | 5.6 | 36 | 256 qam | 12 |
6 | 235000000 | 5.1 | 37 | 256 qam | 13 |
7 | 243000000 | 5 | 37 | 256 qam | 14 |
8 | 251000000 | 4.4 | 36 | 256 qam | 15 |
9 | 259000000 | 4.8 | 36 | 256 qam | 16 |
10 | 267000000 | 4.4 | 37 | 256 qam | 17 |
11 | 275000000 | 4.5 | 37 | 256 qam | 18 |
12 | 283000000 | 3.9 | 36 | 256 qam | 19 |
13 | 291000000 | 4.1 | 37 | 256 qam | 20 |
14 | 299000000 | 4 | 36 | 256 qam | 21 |
15 | 307000000 | 3.9 | 36 | 256 qam | 22 |
16 | 315000000 | 3.5 | 36 | 256 qam | 23 |
17 | 323000000 | 3 | 36 | 256 qam | 24 |
18 | 331000000 | 2.7 | 36 | 256 qam | 25 |
19 | 339000000 | 2.4 | 35 | 256 qam | 26 |
20 | 347000000 | 2.5 | 36 | 256 qam | 27 |
21 | 355000000 | 2 | 36 | 256 qam | 28 |
22 | 371000000 | 2 | 37 | 256 qam | 30 |
23 | 379000000 | 2.2 | 36 | 256 qam | 31 |
24 | 387000000 | 1.7 | 37 | 256 qam | 32 |
1 | Locked | 37.6 | 134 | 0 |
2 | Locked | 37.6 | 107 | 0 |
3 | Locked | 37.3 | 153 | 0 |
4 | Locked | 37.3 | 153 | 0 |
5 | Locked | 36.6 | 182 | 0 |
6 | Locked | 37.3 | 122 | 0 |
7 | Locked | 37.3 | 150 | 0 |
8 | Locked | 36.6 | 202 | 0 |
9 | Locked | 36.6 | 163 | 0 |
10 | Locked | 37.3 | 152 | 0 |
11 | Locked | 37.3 | 176 | 0 |
12 | Locked | 36.6 | 198 | 6 |
13 | Locked | 37.3 | 145 | 0 |
14 | Locked | 36.3 | 294 | 0 |
15 | Locked | 36.6 | 178 | 0 |
16 | Locked | 36.6 | 163 | 0 |
17 | Locked | 36.6 | 207 | 8 |
18 | Locked | 36.6 | 347 | 0 |
19 | Locked | 35.5 | 1255 | 0 |
20 | Locked | 36.6 | 202 | 0 |
21 | Locked | 36.3 | 243 | 0 |
22 | Locked | 37.3 | 162 | 12 |
23 | Locked | 36.6 | 144 | 0 |
24 | Locked | 37.3 | 138 | 0 |
1 | 32600000 | 41.3 | 5120 | 64 qam | 13 |
2 | 39400000 | 41.3 | 5120 | 64 qam | 12 |
3 | 46200000 | 41.8 | 5120 | 64 qam | 11 |
4 | 53700000 | 41.8 | 5120 | 64 qam | 10 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 4 | 0 |
3 | ATDMA | 0 | 0 | 5 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | 4k;fg87dsfd;kfoA,.iyewrkl |
SFID | 27451 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
on 23-08-2022 12:06
Hi @lau04258 thanks for your post here in the Community although I'm sorry to hear of your concerns raised.
I've run some checks for you and there doesn't appear to be any problems on the network and all power levels, upstream and downstream levels so everything is working as it should be.
When you're on the video calls are you operating on wifi or is it an ethernet connection that you have?
Many thanks
on 23-08-2022 12:18
Thanks for responding. I'm operating on WiFi in clear sight of the router. It's not practical to be using a ethernet as it's our living room.
Speeds are good:
on 23-08-2022 12:46
Hi @lau04258 thanks a lot for your quick reply.
Okay thank you for clarifying. Unfortunately, we don't guarantee a wifi speed (although yours posted here should be sufficient for video calling) as there are so many external factors that influence this - it can be the device you're using, the amount of devices you have online at one time for example as well as many more.
I appreciate that wifi is a lot more practical than ethernet due to the fact it's wireless but put simply, a wired connection is always the best performance as it's a direct connection to your Hub and nothing is lost that way.
My best advice would be is that when you're video calls are dropping, to try this via an ethernet cable and I do believe you'll see a real difference. As well as this, please reduce the amount of devices online if you continue to use wifi while you're on these calls as this should help too.
Many thanks
on 23-08-2022 13:25
on 25-08-2022 13:35
Thanks for the update lau04258 and do please keep us up to date with this.
In regards to the frequencies, the Hub 4 doesn't split these for viewing. The only way to see these separately would be to split the SSID's which isn't something we would recommend but can be done. In regards to the channels, the Hub is designed to select the least congested channel available to help improve the performance.
Rob
