on 08-08-2021 14:55
Dear all, quick question i have a netgear ap wac104 what’s best way to connect to hub 3? Can i use wired connection as i have a cable next to hub that goes to netgear ap?
how easy is the configuration?
this is to be used as wireless access point .
kind Regards
sergio
on 08-08-2021 20:19
@Stote wrote:Dear all, quick question i have a netgear ap wac104 what’s best way to connect to hub 3? Can i use wired connection as i have a cable next to hub that goes to netgear ap?
how easy is the configuration?this is to be used as wireless access point .
kind Regards
sergio
Yes, just connect the netgear to the hub with an ethernet cable.. site the AP in a suitable place (close to wherever hte wifi is poor) and it should all "just work" - little/no configuration needed.
