on 11-08-2021 11:27
Hi when I connect to these with WiFi ,I quite often get buffering ,when I check my download speed I sometimes get as low as 1mb ,had broadband for about 3 months and WiFi is pretty poor,I think I'll have to connect with ethernet cable .
Answered! Go to Answer
on 11-08-2021 11:43
on 11-08-2021 11:43
on 12-08-2021 11:21
Hi it seems like my problem could be with the apps on my TV,which is slowing my WiFi ,Disney+ and netflix down,what I've done is login to netflix through my virgin media box and it is working fine ,and is not slowing my WiFi down,I don't think there is a Disney+ channel on virgin media is there?
on 14-08-2021 11:34
Thanks for coming back to us @THOMMO7777 and that is correct that we dont have the Disney+ app available on our boxes at the moment.
Have you tried an ethernet connection to see if that can help you out?
Regards,
Steven_L
on 14-08-2021 12:01
Yes I done that and it's sorted problem out,
on 16-08-2021 12:31
Hey @THOMMO7777,
Thanks for the update, glad to hear this. Do drop back if you need any future assistance.
Kind regards,
