  • 5
Madmax1955
Need to reset VMDG480
How do I factory reset my VMDG480.  Last night it reset the WiFi password but clearly didn’t reset setting password
  • 19.23K
  • 1.68K
  • 4.22K
Re: Need to reset VMDG480
could look at -> https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030... also when resetting hub if held for 30 seconds, other option would be if you have a pc/laptop wired into hub can log into hub via http://192.168.0.1 password changeme (unless changed) and then can go into wireless settings and make any changes.
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
  • 5
Madmax1955
Thanks very much.  Got it sorted now.  Appreciate your help
  • 653
  • 33
  • 45
Hello Madmax1955
Thank you for taking the time to contact us and welcome to the forums. Apologies for the delays in getting back to you but were pleased to hear this has now been resolved. If you need us again in the future don't hesitate to get in touch.
Rob
