on 08-08-2022 14:38
Good afternoon,
I'm writing regarding the estate community that uses VM Broadband as the main ISP for 200+ flats under the same “cable”.
In the last 3 months we started to experience severe internet dropdowns/reconnects that according to network logs from 192.168.0.1 hub settings looks like: “SYNC Timing Synchronization failure - Loss of Sync;CM-MAC= ******;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.0;
In these 3months the issue was reported by multiple people in the estate and engineers visited multiple times, also there were “engineers working in your area” reports from virgin service status website. While after “engineer works” connection stabilised for time being, issues kept coming back after a week.
In this post I’ll try to provide as much details as possible to help engineers to fix this, as well I asked all the estate to provide necessary data from their side, as this situation is affecting a lot of peoples jobs.
Time | Priority | Description |
08/08/2022 13:19:59 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 13:19:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 13:19:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 13:19:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 13:18:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 13:18:18 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Also I have set up a broadband quality monitor:
Working from home in this conditions for 2-3months now is impossible.
Please Help
on 08-08-2022 14:44
In our estate, people are going to work in coffee places with wifi and creating hotspots from mobile phones to get work done, this is insane virgin media...
on 08-08-2022 14:45
on 08-08-2022 15:24
Hi John,
thanks for taking time, here are the tables.
1 | 234750000 | -5.2 | 38 | 256 qam | 13 |
2 | 138750000 | -2.5 | 38 | 256 qam | 1 |
3 | 146750000 | -2.9 | 38 | 256 qam | 2 |
4 | 154750000 | -2.7 | 38 | 256 qam | 3 |
5 | 162750000 | -2.5 | 38 | 256 qam | 4 |
6 | 170750000 | -2.5 | 38 | 256 qam | 5 |
7 | 178750000 | -2.7 | 38 | 256 qam | 6 |
8 | 186750000 | -2.7 | 38 | 256 qam | 7 |
9 | 194750000 | -3 | 38 | 256 qam | 8 |
10 | 202750000 | -3.7 | 38 | 256 qam | 9 |
11 | 210750000 | -4.7 | 38 | 256 qam | 10 |
12 | 218750000 | -5.4 | 37 | 256 qam | 11 |
13 | 226750000 | -5.5 | 37 | 256 qam | 12 |
14 | 242750000 | -4.7 | 38 | 256 qam | 14 |
15 | 250750000 | -4.4 | 38 | 256 qam | 15 |
16 | 258750000 | -4.2 | 38 | 256 qam | 16 |
17 | 266750000 | -4 | 38 | 256 qam | 17 |
18 | 274750000 | -4 | 38 | 256 qam | 18 |
19 | 282750000 | -3.9 | 38 | 256 qam | 19 |
20 | 290750000 | -4.2 | 38 | 256 qam | 20 |
21 | 298750000 | -3.9 | 38 | 256 qam | 21 |
22 | 306750000 | -3.5 | 38 | 256 qam | 22 |
23 | 314750000 | -3.4 | 38 | 256 qam | 23 |
24 | 322750000 | -3.5 | 38 | 256 qam | 24 |
1 | Locked | 38.6 | 143806 | 624598 |
2 | Locked | 38.6 | 154315 | 212564 |
3 | Locked | 38.6 | 128204 | 203273 |
4 | Locked | 38.6 | 119944 | 157202 |
5 | Locked | 38.9 | 116087 | 126264 |
6 | Locked | 38.6 | 112786 | 133604 |
7 | Locked | 38.9 | 108119 | 132078 |
8 | Locked | 38.6 | 101262 | 154724 |
9 | Locked | 38.6 | 96262 | 179866 |
10 | Locked | 38.9 | 100715 | 231911 |
11 | Locked | 38.6 | 136253 | 374035 |
12 | Locked | 37.6 | 129557 | 693754 |
13 | Locked | 37.6 | 126262 | 697450 |
14 | Locked | 38.6 | 166607 | 493745 |
15 | Locked | 38.6 | 162597 | 418096 |
16 | Locked | 38.9 | 149289 | 365360 |
17 | Locked | 38.9 | 122296 | 260231 |
18 | Locked | 38.9 | 105436 | 288607 |
19 | Locked | 38.9 | 105770 | 325545 |
20 | Locked | 38.6 | 104447 | 352503 |
21 | Locked | 38.6 | 101439 | 327485 |
22 | Locked | 38.6 | 104233 | 229141 |
23 | Locked | 38.9 | 103076 | 223924 |
24 | Locked | 38.9 | 106701 | 218349 |
1 | 49599984 | 30.5 | 5120 | 32 qam | 6 |
2 | 30100000 | 33.5 | 5120 | 32 qam | 9 |
3 | 43099939 | 33 | 5120 | 32 qam | 7 |
4 | 36600000 | 34 | 5120 | 32 qam | 8 |
5 | 23599693 | 33.2 | 5120 | 32 qam | 10 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 4 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 08-08-2022 15:25
AND here are Network logs:
08/08/2022 14:14:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:14:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:14:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:14:14 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:14:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:14:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:12:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:12:38 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:08:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:08:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:15 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:06:9 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:03:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2022 14:03:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 08-08-2022 15:31
on 08-08-2022 15:54
Hi John,
just did EXACTLY as you said (with exact timer for 60sec on phone).
managed to swap one channel from 32qam to 16qam 😄
let me know what tables should I post right now.
on 08-08-2022 16:00
on 08-08-2022 19:12
Thanks for posting this Paul.
I'm one of your neighbours and have been experiencing the same as you for months now.
on 09-08-2022 12:21
Hi John,
did all the things you have listed, tighten up all cord ends, used brand new ethernet cable, all looks tight and clean. No loose cords.
Yesterday also spoke with virgin tech person, he got all my notes on the issue, at the end of the day I received text from virgin that the issue has beed solved and I need to reset VM Hub and wait 30min.
after 24h of observation, here are the results.
Please find attached thinkbroadband screenshot (the red line is when 30min reset/restart took place). Although in chart looks like there was 10 ping spikes, on connected devices felt WAY more..
Also will copy/paste same logs that you asked yesterday.
Greatly appreciate your help.
