  • 30
NGC
Message 1 of 5
Moving my hub
I want to move my hub from near my tv and place it on a high unit to try and improve my very poor wifi signal, but the main VM cables are not long enough, will VM be able to send me a connector and a longer cable or is it just "down to me"
Help appreciated
Neil
  • 25.98K
  • 1.1K
  • 4.23K
Message 2 of 5
Re: Moving my hub
you will be better going to modem mode and using a good router
  • 232
  • 32
  • 38
Shweby
Superfast
Message 3 of 5
Re: Moving my hub
Virgin charge £99 for a non fault callout, even if it is just for a longer cable. You may be able to get help from retentions, but unlikely. Wouldnt advise doing it yourself with your own cable as has the pottential to cause alot of issues. And i doubt moving the hub a couple of feet higher would improve your wifi. Have you split your 2g and 5g networks for better wireless reception? Or as said above, invest in a 3rd party router.
______________________________________
I work for Virgin Media, but all opinions are my own.
  • 30
NGC
Message 4 of 5
Re: Moving my hub
Thank for the advice,
i don’t understand what you mean about separating 2g from 5g
  • 19.22K
  • 1.68K
  • 4.22K
Message 5 of 5
Re: Moving my hub
@NGC could take a look at -> http://community.virginmedia.com/t5/Networking-and-WiFi/Connecting-WiFi-adaptor-for-air-con/td-p/362... this shows how to split the wifi..
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
