on 21-10-2021 22:09
Quick question - i have WiFi Pods in the house. If I move, are the pods paired to the router, or could i simply take them with me to the new home and use?
on 22-10-2021 14:00
on 22-10-2021 14:11
I don't even think the house is cabled yet.
Would you normally take the Hub with you when you move?
on 22-10-2021 14:34
22-10-2021 14:37 - edited 22-10-2021 14:37
@jbrennand wrote:
Only if the house is VM cabled and has an active service. I am not 100% sure if you can just take the equipment across with you these days (someone else should comment).
It depends on where you move as to whether you transfer your existing kit or need an engineer to come out and install new kit.
Virgin Media will tell you when it's arranged which one is possible as it's related to the billing systems.
