on 04-12-2021 17:59
Hey folks,
I want to set up a mesh network, have a 3rd party router I want to use, but when I log in to the Hub 3.0 admin (http://192.168.0.1) the option to switch the hub to modem mode is not visible. Any ideas?
on 04-12-2021 19:07
Are you based in the UK or Ireland?
If you are based in Ireland you'll need to speak to them to set it up for you. https://www.virginmedia.ie/contact/
If you are based in the UK a reboot of the hub should allow you to see that option
on 04-12-2021 19:16
Also if in Ireland ask to put back to IPv4 if you are a gamer as the IPv6 solution with Liberty Global in Ireland is no good for gaming.
