on 20-05-2022 15:42
I currently have the Hub 3 with WIFI turned off and a TP-Link Deco Mesh system, with the main node in Access Point configuration. I did this because I read that the Hub 3 cannot be put into "Modem mode".
I have been offered a Hub 5 and I understand it can be put into "Modem mode".
I want to set it up, change the SSID and password to the same as my current Hub 3 ( so I don't have to mess around with all my smart plugs etc) and set up my Mesh system again.
If, once I have made those changes, I set the Hub 5 in "Modem mode", do I now take the main Mesh node out of AP mode and into router mode? What difference would that make?
If I do need to change it to router mode, will I need to do anything else?
Answered! Go to Answer
on 20-05-2022 17:51
All VM hubs work far better in modem mode, they are not running a WAP, DHCP server or network switching, much less load on their underpowered CPUs.
on 20-05-2022 15:50
Yes; the 5 can be put into modem mode, but then so can the Hub 3 - I've been running one like that for years!
To be honest, you probably wouldn't notice any difference between the 3 and 5 if both in modem mode. You are right about the mesh mode though, except put the main unit into router mode BEFORE turning the Hub 3 or 5 into modem mode.
on 20-05-2022 17:51
on 20-05-2022 18:50
Apart from changing the main Deco to router mode from AP mode, do I need to do anything else (i will have changed the SSID and password to match my current Hub 3)?
I current have an ethernet 8 switch box plugged into the Deco, I assume, in modem mode, the Hub 5 still only has the 1 ethernet socket enabled?
20-05-2022 18:55 - edited 20-05-2022 18:58
@keithynb wrote:I current have an ethernet 8 switch box plugged into the Deco, I assume, in modem mode, the Hub 5 still only has the 1 ethernet socket enabled?
Yes but the a simple switch need to connect to the Deco other port not sure how the auto-sensing works you might need to just connect the Deco to the hub without the switch at first.
