Modem Mode Hub5x
scarter177
Hi all, is there any ETA when modem mode will be coming to the Hub5x?
I need to access my home server from another household, I'm using a VPN, however both households have the same subnet, so I can't access it. I'd be able to solve this by being able to put my hub5x in modem mode, then setting up my own OPNsense router and changing the subnet. Both households have the Hub5x, so unfortunately I can't change either one. I don't want to double nat.
4 REPLIES 4
...we can't have nice things...there is no ETA
Check this suggestion? https://community.virginmedia.com/t5/Tech-Chatter/For-those-people-with-a-Hub5x/td-p/5567895
you can check this may only work on 1Gb port
Hub 5x WORKING modem mode : r/VirginMedia (reddit.com)
Thanks for the suggestion, I'll check it out 🙂
