  • 23
Message 1 of 11
Mesh networking
I have a Virgin hub router with one PC running W10, a Synology NAS, and a node of a Mercusys Halo mesh network.  I can't work out how to set up sharing between the hard wired PC on the Virgin router and a laptop (or whatever) on the mesh network. Any thoughts please?
Bernie
  • 24.81K
  • 1.43K
  • 3.16K
Message 2 of 11
Re: Mesh networking
Sharing of what exactly?
  • 23
Message 3 of 11
Re: Mesh networking
Sharing/copying files
B
  • 24.81K
  • 1.43K
  • 3.16K
Message 4 of 11
Re: Mesh networking
You need to allow network sharing between the machines and also make sure the network is set to a private network, not public.
  • 23
Message 5 of 11
Re: Mesh networking
Thanks, but I already have that.
The laptop can see the mesh router, and it has shared folders
The PC can see the Virgin router.
The Virgin router can see the mesh router, and vice versa, with the Virgin router as the gateway.
...but the PC can't see the mesh router nor the laptop connected to it
B
B
  • 11.97K
  • 933
  • 1.53K
Message 6 of 11
Re: Mesh networking
Are the devices in the same Workgroup and Network ?
Mike Robinson
  • 24.81K
  • 1.43K
  • 3.16K
Message 7 of 11
Re: Mesh networking
If you're using the mesh as a router then the virgin hub should be in modem mode unless the mesh doesn't support routing.
Then again, they look like they only have 10/100Mbps ports so not great in the scheme of things.
  • 23
Message 8 of 11
Re: Mesh networking
This is the current setup. The Halo network sees the Virgin router as it's gateway. Everything works fine apart from the fact that computers on one network can't see those on the other. I don't want the Halo router to run the network as it only goes at 100Mbs, which is fine for laptops etc on wifi, but not for this PC.
B
  • 24.81K
  • 1.43K
  • 3.16K
Message 9 of 11
Re: Mesh networking
Are the Halo's setup in AP/Bridge mode if the hub is still in router mode?
  • 23
Message 10 of 11
Re: Mesh networking
Actually, I seem to have sorted it.  I turned off the DCHP server on the Halo ethernet connected router and rebooted all the mesh nodes. Everything now takes its address from the Virgin router and everything can see everything else.
Don't seem to be able to access the Halo router now, but I don't need to at the moment, maybe never.
B
