  • 7
Message 1 of 8
Media hub 4 Printer and PSP Connection problems
I have connected my Canon Printer and PSP VITA with the WPS button.
Both keep losing connection more than keeping it.
I use the Devices in the same room as my Media hub 4.
  • 12.27K
  • 950
  • 1.57K
Message 2 of 8
Re: Media hub 4 Printer and PSP Connection problems
Stop the problems permanently and use Cat 6 ethernet cables to connect the devices.
Mike Robinson
  • 7
Message 3 of 8
I can’t connect my PSP Vita wired and the printer is on the other side of the room.
I got the Hub 4 because I thought it would be easier but drops wireless connection.
i did not have any problems with the Hub 3.
  • 25.14K
  • 1.44K
  • 3.2K
Message 4 of 8
The Hub4 has more issues than the Hub3, particularly with compatibility and wifi stability.
Have you enabled B/G/N connections on the 2.4Ghz band to allow it to work with older devices?
  • 7
Message 5 of 8
Thanks for that I will give it a try.
I don’t understand why I should have more problems with newer tech and paying more for it.
I want it simple!!
Thanks.
  • 7
Message 6 of 8
I tried the b/g/n and still not working
  • 25.14K
  • 1.44K
  • 3.2K
Message 7 of 8
Because the hubs are cheap mass-produced kit.
Have you split the 2.4Ghz and 5Ghz bands so you can choose which one in particular to connect to?
  • 3.34K
  • 257
  • 332
Message 8 of 8
Hey Scoobybad,
Sorry to hear that you're having issues with some of the devices that you're trying to connect to your Hub4.
Have you been able to get this issues resolved with the help of the community members?
I have checked things on your account from our side and cannot find any issues from here.
Steven_L
