  • 17
grahamp1
Manually select Hub 3 channel - seems impossible.
Got a sophisticated realtime network tool that provides real-time channel displays. I want to select the least busy channel (of course) but don't seem able to do it.
VM advice is to reboot the Hub 3 and let it select the channel. Don't know what their algorithm is, but it always selects the most cluttered channel.
Any advice as to how I can select my own channel ?
  • 2.34K
  • 113
  • 304
jpeg1
Problem sorter
Re: Manually select Hub 3 channel - seems impossible.
Channel setting is in the WiFi settings menu.
Only use channels 1, 6 or 11
  • 21.77K
  • 620
  • 3.62K
Sephiroth
What you'll find id that everyone else is doing the same and there is round robin congestion.
  • 11.37K
  • 1.04K
  • 2.43K
griffin
Check you have Smart WiFi disabled.
The least congested channel it is not necessarily the best channel as overlapping channels cause far more damage.
I would also bear in mind wireless scanner apps do not show interference from non 802.11 devices, which is responsible for the majority of interference on the 2.4GHz band.
  • 17
grahamp1
Wouldn't allow any changes. Couldn't select channel at all.
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Hmmm sounds like the Smart WiFi option may have been enabled, is this happening on both 2.4 and 5Ghz frequencies?
Kind rgds
Ralph_R
Forum Moderator
