  • 6
Alexcairn
Message 1 of 8
Main hub not connecting with phone
My phone was connected to main hub but recently has now not been able to recognise hub. It will still link with the other hub but not the main one.
I have tried network reset. Linking WPS, turning on and off for both phone and WiFi. Have rung virgin whonsay no issue with connection. It is a android.
Other Android iPad and television are all working just my phone that is not any ideas?
  • 101
  • 14
  • 22
ciaran2506
Up to speed
Message 2 of 8
Re: Main hub not connecting with phone
If your other devices are connecting fine sounds more like an issue with your Android smartphone.
Have you tried deleting the connection from your phone, then re-connecting from scratch? If that still doesn't work, have you tried resetting your phones network settings to default? Doing so will delete any previous Wi-Fi connections
  • 6
Alexcairn
Message 3 of 8
Thank you, I have tried but still not working, just done a factory reset and still nothing.
the phone picks up other WiFi addresses but just not the home one.
any ideas?
  • 101
  • 14
  • 22
ciaran2506
Up to speed
Message 4 of 8
Does your phone see your Wi-Fi network and just won't connect, or does it just not see it there at all?
You could try doing a factory reset on the hub aswell and see if it can connect then.
  • 6
Alexcairn
Message 5 of 8
No longer sees the hub, it was yesterday, but now not at all.
Will try the factory reset on the hub.
  • 6
Alexcairn
Message 6 of 8
This has not worked, I may need to contact virgin media, unless anyone has an ideas?
  • 9.41K
  • 978
  • 1.48K
Message 7 of 8
You dont say which Hub model you have - if its a Hub3 try renaming the 2.4 & 5 GHz networks to "split" them and see if your phone can connect to each of them individually
  • 6
Alexcairn
Message 8 of 8
It is 3.0,
the hub main hub and the booster hub have different names.
