on 08-06-2021 11:50
MacBook Pro using Catalina 10.15.7 not connecting to Hub 4
safari hangs but google chrome works as does my iPhone XS on the hub 4.
got sent by virgin to Gadget Helpline who said they could help but I had to pay!
any thoughts? Double bind I can’t upgrade operating system because I can’t get on the internet and 12 gig install a bit big for my phone
Answered! Go to Answer
on 08-06-2021 14:24
on 09-06-2021 13:43
on 08-06-2021 13:17
on 08-06-2021 13:34
Have you tried using a Cat 6 cable with a USB adaptor if required. It's always good to have a wired option in any case, especially as VM always request wired tests for troubleshooting.
on 08-06-2021 14:02
Only the MacBook Pro and yes Chrome works fine
i have not tried the forget network trick as it can obviously see an use it - except with Safari
any thoughts?
on 08-06-2021 14:04
No not yet.
the problem is not that the MacBook doesn’t work with the hub. It’s that Safari doesn’t work with it.
safari works fine if I connect to my portable my fi box (O2)
it must be a software incompatibility?
on 08-06-2021 14:24
on 08-06-2021 14:30
Sorry pressed the wrong button
there are no error messages - it just “hangs”
the blue loading bar in safari goes about a 1/10th of the way along the bar and stops
on 08-06-2021 14:43
on 08-06-2021 16:25
Try the Apple forums/help;
https://support.apple.com/en-gb/HT204098
on 08-06-2021 16:29
