on 05-12-2021 14:04
I've recently upgraded to the M200 package, and got the Superhub 3 just over a month ago. All working well for the first few weeks, had an area outage last month but apart from that pretty good. Download speed usually 219 and Upload 20mbps.
However since yesterday I've done tests using different websites the upload speed has dropped to 2-3mpbs and barely gets over 5. Download is still the same though, and I've done router reboots too. Same result. I've also tested with another machine and still the same low upload speed. On my phone and iPad via Wi-fi it barely gets over 1mpbs and that's sitting in front of my router.
I spoke to a VM tech yesterday and they suspected one of the wi-fi devices connected (2 smartphones 2 iPads) could be uploading something large and taking up bandwidth, but we switched off wi-fi for all those and just did my PC via ethernet. No improvement.
There's also a Wi-fi extender adaptor that runs from the hub, which goes into the detached garage at the back of my garden, but I cant imagine its this causing low upload as nothing's connected to it when I'm testing in the house.
I do video calling stuff for my work so the upload speed is the one I am keeping an eye on. I can just about get by with 3-4mpbs but it makes my video a bit laggy for a few seconds.
Is it VM's issue or is this something I can fix? I think I've tried each possible troubleshooting scenario.
on 05-12-2021 15:53
Hi @Daniel_C
You should post your router stats here for the learned members to check what the problem is and offer assistance.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return.
Don't login, instead below there click on Check Router Status
From the Router Status” page copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages.
You could also set up a BQM monitor at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
In the URL box paste the link you copied and then click OK
on 05-12-2021 16:15
1 | 331000000 | 13.8 | 38 | 256 qam | 25 |
2 | 203000000 | 13 | 37 | 256 qam | 9 |
3 | 211000000 | 13 | 37 | 256 qam | 10 |
4 | 219000000 | 13.1 | 37 | 256 qam | 11 |
5 | 227000000 | 13.3 | 37 | 256 qam | 12 |
6 | 235000000 | 13.1 | 37 | 256 qam | 13 |
7 | 243000000 | 12.9 | 37 | 256 qam | 14 |
8 | 251000000 | 12.8 | 37 | 256 qam | 15 |
9 | 259000000 | 12.9 | 37 | 256 qam | 16 |
10 | 267000000 | 12.8 | 37 | 256 qam | 17 |
11 | 275000000 | 12.5 | 37 | 256 qam | 18 |
12 | 283000000 | 12.1 | 37 | 256 qam | 19 |
13 | 291000000 | 11.5 | 38 | 256 qam | 20 |
14 | 299000000 | 11.5 | 38 | 256 qam | 21 |
15 | 307000000 | 12 | 38 | 256 qam | 22 |
16 | 315000000 | 12.8 | 38 | 256 qam | 23 |
17 | 323000000 | 13.3 | 38 | 256 qam | 24 |
18 | 339000000 | 14 | 38 | 256 qam | 26 |
19 | 347000000 | 14 | 38 | 256 qam | 27 |
20 | 355000000 | 14 | 38 | 256 qam | 28 |
21 | 363000000 | 14 | 38 | 256 qam | 29 |
22 | 371000000 | 14 | 40 | 256 qam | 30 |
23 | 379000000 | 14 | 38 | 256 qam | 31 |
24 | 387000000 | 14.1 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 7 | 0 |
2 | Locked | 37.3 | 19 | 0 |
3 | Locked | 37.3 | 16 | 0 |
4 | Locked | 37.6 | 7 | 0 |
5 | Locked | 37.6 | 27 | 0 |
6 | Locked | 37.6 | 9 | 0 |
7 | Locked | 37.6 | 8 | 0 |
8 | Locked | 37.3 | 10 | 0 |
9 | Locked | 37.3 | 37 | 0 |
10 | Locked | 37.6 | 15 | 0 |
11 | Locked | 37.6 | 11 | 0 |
12 | Locked | 37.6 | 12 | 0 |
13 | Locked | 38.6 | 24 | 0 |
14 | Locked | 38.9 | 13 | 0 |
15 | Locked | 38.6 | 13 | 0 |
16 | Locked | 38.9 | 11 | 0 |
17 | Locked | 38.9 | 8 | 0 |
18 | Locked | 38.6 | 8 | 0 |
19 | Locked | 38.9 | 12 | 0 |
20 | Locked | 38.9 | 9 | 0 |
21 | Locked | 38.9 | 7 | 0 |
22 | Locked | 40.3 | 11 | 0 |
23 | Locked | 38.9 | 6 | 0 |
24 | Locked | 38.9 | 13 | 0 |
on 05-12-2021 16:15
1 | 25798984 | 38.8 | 5120 | 16 qam | 6 |
2 | 46200107 | 38.3 | 5120 | 64 qam | 3 |
3 | 39399976 | 38.3 | 5120 | 64 qam | 4 |
4 | 32600102 | 38.3 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 93 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 05-12-2021 16:16
05/12/2021 16:09:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 16:07:24 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 16:06:47 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 14:53:9 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 11:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 18:22:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/11/2021 23:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/11/2021 14:10:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/11/2021 11:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 11:13:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/11/2021 23:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/11/2021 11:43:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/11/2021 11:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/11/2021 03:33:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2021 23:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2021 10:31:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2021 11:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2021 18:18:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/11/2021 23:21:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 05:26:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 05-12-2021 16:18
I did the test on my kit in myvirginmedia as well and its saying there's a network issue that could be affecting the service, maybe a signal-to-noise ratio. I think this is linked with interference with the cabling going into my home.
on 05-12-2021 16:22
You Downstream is too high and your T3’s are horrendous. Need a technician to sort out.
on 05-12-2021 16:27
Possibly due to the network issue in the area? Or more the cabling to my house?
on 05-12-2021 22:17
Probably not your cable. Keep a watch on the local issue, VM will not despatch any technicians to users addresses until it is fixed and even then you need to report the problem anew.
Check with Area faults on www.virginmedia.com/servicechecker or 0800 561 0061 If you have a VM landline 150
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
on 05-12-2021 23:22
I have exactly the same issue. Nothing changed my side but Upload has dropped to 2-3mb from 20mb in the last few days.
My SH3 is in Modem Mode and my wireless devices I can see all activity on with the app, so there isn't any device uploading a lot my side. My speed test is at the wireless router level.
When I login to VM it says all is dandy in my area, but when I continue to test equipment then says there is an issue in my area.
So you're not alone!
