on 29-07-2021 17:44
on 29-07-2021 18:14
Modem mode allows you to disable the router functionality of the Superhubs and use them only as a cablemodem. You can then connect your own router of choice using one single Ethernet cable instead.
on 29-07-2021 18:14
