on 05-08-2021 12:13
Every morning I lose broadband access for between 1 to 5 minutes, several times between 08:00 and 11:00. It doesn't seem to happen thereafter. Whenever I check the service status it says it is OK and I obviously can't check it when I've got no access. Any idea what's going on and should I log it as a complaint? I have trouble finding where I put in a complaint though.
Answered! Go to Answer
on 11-08-2021 17:11
Done that and I've lost connectivity twice since then this afternoon 🙂
John.
on 12-08-2021 11:27
Had real problems this morning between 09:15 and 10:30 kept losing internet access (DNS Server not responding) - no change to light on the box stayed low white throughout. Each outage was for about 2-3 minutes and I must have had about 10-12 outages. Seems OK now no problems for the past hour. John.
on 14-08-2021 12:21
Thanks for your messages and clearing data protection, PMBlogger,
I have set up an engineer’s visit for you which you will be able to view from your online account here.
Cheers,
Corey C
on 17-08-2021 10:58
Thanks Corey, he came yesterday and replaced/tidied up some of the outside cabling. I was up a bit late this morning (having fractured my patella and hobbling about on crutches) but again had the usual problem between 09:15 and 09:25. Screen shot if it is any help:
on 19-08-2021 11:05
Thanks for the update @PMBlogger.
Sorry to hear the issue persists after the given appointment.
In this case please try setting up a free “Broadband Quality Monitor” to monitor dropouts on your service post appointment: https://www.thinkbroadband.com/broadband/monitoring/quality . This will help us further identify where the problem may lay.
on 19-08-2021 12:11
OK many thanks, I have now set that up. What do I do with the results?
on 19-08-2021 12:23
on 19-08-2021 15:11
https://www.thinkbroadband.com/broadband/monitoring/quality/share/438c3cb6de671f2f8efc767b9e683fccc6...
Not sure if I have done this right, JOhn.
on 19-08-2021 15:23
on 21-08-2021 17:54
Hey @PMBlogger,
Thanks for the link to the BQM. Looks relatively healthy other than the spike every 8 hours are so. How have your devices been performing during these?
Just had a look from our end and levels are all coming back all green and clear currently.
Kind regards
