Message 1 of 10
Losing WiFi and cannot work from home
WiFi signal from hub 3 regularly drops but seemingly only when in zoom or video calls. Also tried to connect via ethernet cable and same thing happens. WiFi drops, loses network, cannot reconnect for minutes or unless I reset router. The issue seems to be the service and not the hardware as when streaming like with Netflix we have no issues.
  • 14.73K
  • 620
  • 1.42K
Message 2 of 10
Re: Losing WiFi and cannot work from home
Try zoom or video calls with hub in modem mode
  • 24.4K
  • 1.4K
  • 3.1K
Message 3 of 10
What does the service status page show?
Message 4 of 10
I had plugged another router into the hub to effectively use it for just the modem, then connected to that, same issue keeps happening
Message 5 of 10
Service says its fine I'm completely stumped
  • 11.49K
  • 891
  • 1.46K
Message 6 of 10
What is your connection like using a direct connection with a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 3.47K
  • 270
  • 468
Superfast
Message 7 of 10
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
  • 8
Message 8 of 10
Can Virgin please sort this out?!  I am in Telford and when I phone 150 I get an automated voice telling me of 'intermittent' issues in our area with Broadband.  This has been happening for over a week now - and with a lot of us having to work from home and RELYING on broadband - WE NEED THIS TO BE SORTED.
The service from Virgin is shocking.  Ive made a complaint about recent service I received, and the complaint hasn't even been acknowledged (this dates back to the summer) - so who on earth do I complain to now??
RUBBISH VIRGIN. Please pull your fingers out.
  • 3.47K
  • 270
  • 468
Superfast
Message 9 of 10
Why are you replying to this thread?
  • 24.4K
  • 1.4K
  • 3.1K
Message 10 of 10
Please post your own thread if you require assistance
