Possibellie
Latency Issues
For 3 weeks now I've had some bad ping spikes via wired and wireless. It's happening on multiple devices and I'm starting to lose my patience as I've had hardly any help when I've called support. The most help I've had is from someone on twitter. So please, any help or suggestions would be amazing.
I've tried doing a factory reset several times via the router and on the hub settings and the issue still persists.
  • 33
  • 7
samuarl
Re: Latency Issues
Do you happen to be in North London? The time frame matches with an issue other customers have reported.
Possibellie
Re: Latency Issues
Yeah, I am.
  • 33
  • 7
samuarl
Re: Latency Issues
Get your thumbs warmed up and start twiddling. There's nothing you can do but wait.
This post is currently the closest you will get to an acknowledgement of there being an issue from VM
Possibellie
Re: Latency Issues
Thank you so much!
  • 597
  • 18
  • 31
Re: Latency Issues
Hi Possibelllie
Thanks for getting in touch.
Just wanted to check in and see if you have seen any improvements at all?
Nat
