on 07-03-2022 11:32
Just installed the new Hub5 and one laptop can't connect to it. Every other device, laptops, iPads, phones, SmartTV is fine. The problem is my work laptop, Lenovo ThinkPad X250, Win10 64bit ~5 years old, but it was fully rebuilt last year.
The network simply isn't visible to the laptop at all. It doesn't appear in the list. I can successfully connect to other wireless networks, so there isn't a laptop fault.
The network adapter is an Intel Dual Band Wireless-AC 7265, so it should work. The driver is from 2018, but unfortunately I can't check for an update as I don't have local administrator access.
I've tried the following:
I can see from the forums that this is a known problem, so Virgin would you please warn people who have older devices before recommending they switch. Using an ethernet cable isn't an acceptable option, as the router is at the other end of the house to the office.
Is it possible to go back to the Hub3?
on 07-03-2022 11:37
you can go back to the hub3 - it will need re activating - offshore see to have problems doing it and may come up with a load of reasons it cannot be done - all untrue so just keep at them if you get offshore
dial 150 or 0345 454 1111 and follow the prompts to - 'thinking of leaving us' - dont worry about that they do much more - open 8am -10pm 7 days a week - should take you to a UK call centre
theres a freephone number 0800 052 0422. You need option 4 to speak to retentions
on 07-03-2022 13:42
on 07-03-2022 13:46
@legacy1 wrote:
Why go back when you can go forward with the hub in modem mode and your own wifi router with 1Gb ports
ahhh modem mode and the 1gig ports - the answer to all problems or so it would seem 😋
on 09-03-2022 13:57
Hi @sigridir,
I'm very sorry to hear that you're having some problems connecting your work laptop to the Hub 5 at the moment. It's strange that it's just the one device of yours that's having the problem.
I'm going to send you a private message in a few moments so we can take some further details and have a closer look at things for you. Please respond to this at your earliest convenience and we can go from there.
on 11-03-2022 15:53
Zach has asked the customer join him in PM so that we can re-activate his hub 3 should he wish, we would need to pass data protection in order to do that.
Kind regards,
Zak_M
on 11-03-2022 15:55
Kind regards,
Zak_M
ahhhh thanks - so can i now take it we [vip's and others] can flag posts for staff to reactivate hubs if required
