on 07-04-2022 19:24
I have been with virgin since the 15th of March and never had a day of it being normal. 2 engineers have been out and still problems and they will not do anything about it. I have gig1, do these readings look correct ?
Answered! Go to Answer
on 08-04-2022 08:42
Looks like you have high utilisation at peak times on your network plus a hint of noise. One for the VM forum team.
on 07-04-2022 19:25
on 07-04-2022 19:33
Please copy and paste the tables
on 07-04-2022 19:59
25 | 331000000 | 2.2 | 39 | QAM256 | 25 |
10 | 211000000 | 3.1 | 39 | QAM256 | 10 |
11 | 219000000 | 3.1 | 39 | QAM256 | 11 |
12 | 227000000 | 3 | 39 | QAM256 | 12 |
13 | 235000000 | 3 | 38.6 | QAM256 | 13 |
14 | 243000000 | 3 | 39 | QAM256 | 14 |
15 | 251000000 | 3.1 | 39 | QAM256 | 15 |
16 | 259000000 | 3.3 | 38.6 | QAM256 | 16 |
17 | 267000000 | 3.2 | 39 | QAM256 | 17 |
18 | 275000000 | 3.1 | 39 | QAM256 | 18 |
19 | 283000000 | 2.6 | 38.6 | QAM256 | 19 |
20 | 291000000 | 2.8 | 39 | QAM256 | 20 |
21 | 299000000 | 3.5 | 39 | QAM256 | 21 |
22 | 307000000 | 3.6 | 39 | QAM256 | 22 |
23 | 315000000 | 3.1 | 38.6 | QAM256 | 23 |
24 | 323000000 | 2.5 | 38.6 | QAM256 | 24 |
26 | 339000000 | 2 | 39 | QAM256 | 26 |
27 | 347000000 | 2 | 39 | QAM256 | 27 |
28 | 355000000 | 2 | 39 | QAM256 | 28 |
29 | 363000000 | 2.1 | 39 | QAM256 | 29 |
30 | 371000000 | 2.1 | 39 | QAM256 | 30 |
31 | 379000000 | 2.1 | 38.6 | QAM256 | 31 |
1 | 139000000 | 5.3 | 39 | QAM256 | 1 |
2 | 147000000 | 5 | 39 | QAM256 | 2 |
3 | 155000000 | 4.8 | 38.6 | QAM256 | 3 |
4 | 163000000 | 4.4 | 38.6 | QAM256 | 4 |
5 | 171000000 | 3.8 | 38.6 | QAM256 | 5 |
6 | 179000000 | 3.5 | 38.6 | QAM256 | 6 |
7 | 187000000 | 3.5 | 38.6 | QAM256 | 7 |
8 | 195000000 | 3.5 | 38.6 | QAM256 | 8 |
9 | 203000000 | 3.3 | 38.6 | QAM256 | 9 |
25 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.605377 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.605377 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
5 | Locked | 38.605377 | 0 | 0 |
7 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.605377 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM2048 | 759 |
159 | Locked | 42 | -1 | 96573019 | 0 |
on 07-04-2022 20:07
Do post the rest if you are able to. Generally they look okay so far (although 3.1 downstream QAM is half what it should be).
on 07-04-2022 22:01
on 07-04-2022 22:01
on 07-04-2022 22:17
Yeah nothing major that I can see. Perhaps set up a BQM and share its link here so it can be monitored over time https://www.thinkbroadband.com/broadband/monitoring/quality
on 07-04-2022 22:35
on 08-04-2022 08:42
