on 04-12-2022 12:23
Does anyone know if it's possible to bypass or change the wifi password complexity on the hub 4, so it doesn't require a number and upper case letter.
I've recently moved to VM from BT and wanted an easy life, but have a number of wifi devices which are a PITA to change.
on 04-12-2022 12:38
You can now do it on the connect app when you have connected to your hub using the app click on broadband at the bottom and once you are on the page you will see a plus in the top right click on that and you will see options click on network and you will get the option to change the name of the network and password
on 04-12-2022 13:16
Thanks Portery, tried the connect app but when I click on the Broadband button, it says it cant find the hub. The help says to restart the hub, close the app etc, which I've tried, but still not connecting.
Overall, the VM experience has so far been pretty poor. I certainly wouldn't recommend it to anyone.
on 04-12-2022 13:25
Hi @MiloO
Use a web browser and log into the hub interface.
192.168.0.1 or 192.168.100.1 if in modem mode
The go to Advanced Settings > Wireless > Security >
You can then alter the WiFi Network Name (SSID) and the WiFi password (security key)
If you click on the question mark icon next to each field you will see a pop up box explaining which characters can be used and the minimum/maximum length allowed.
Then scroll to the bottom of the page and click Apply changes.
on 04-12-2022 13:37
Thanks newapollo, the problem is the hub4 wifi password criteria requires a number and upper case character. My old BT password is all lowercase and I wanted to keep it the same to save the hassle of changing all my devices.
on 06-12-2022 14:34
Hi MiloO
Thanks for posting in regards to your Hub 4 and wireless network password, to ensure we're making everything as secure as possible we ask for a mixture of characters for the password. Apologies for any inconvenience caused.
Rob
