on 13-08-2021 09:59
I'm just going to ask what does the power light just the powerlight flashing green mean?
on 13-08-2021 10:16
on 13-08-2021 10:29
@lotharmat wrote:
On hub 3? Not activated I believe!
https://www.virginmedia.com/help/virgin-media-what-do-the-lights-on-your-hub-mean
can mean that but much more - mainly that there is some sort of connection fault which i guess not activated falls into but damaged cable or an outage of some sort are more likely on an existing connection as well as a self install as most hubs now come activated to the account
on 15-08-2021 10:42
Hi Nashia,
Thanks for reaching back out to us in our community, how are things now with your Hub, has the light now stopped flashing Green?
I have tried to have a look at things our end however I wasn't able to locate your account with the details we have for you, if you are still facing the same issue I will be more than happy to help further if required?
Paul.
