on 22-05-2021 14:19
Had Virgin broadband installed yesterday. Main Sky Q box connects fine (this is close to Virgin Hub 4 router).
Sky Q mini box for second TV won't connect to Virgin wifi. I key in wifi password and the box connects for a few seconds and I get a TV picture then it drops out. Have repeated this several times.
Can anyone help?
on 22-05-2021 14:25
@chrise66 wrote:Had Virgin broadband installed yesterday. Main Sky Q box connects fine (this is close to Virgin Hub 4 router).
Can anyone help?
The mini boxes connect back to the main Q box via WPS, not your Wifi.
You need to network/factory reset the Mini box and follow the instructions it gives to connect it via WPS back to the main Q box.
on 24-05-2021 08:42
Thanks for answering : )
Why does the Sky mini box ask which wifi network to connect to though if it connects via WPS?
on 24-05-2021 09:17
@chrise66 wrote:Thanks for answering : )
Mine have never done that.
They always ask to push the WPS button on the nearest other Sky Q box then it just auto connects.
on 24-05-2021 09:24
When not connected it will display this screen simlair to the Main Q, but if you reset the Network settings on the Mini it will go through a Set up screen to WPS it on another Q Device (main box). This will make the connection, no need to enter any passwords as your Mini gets its connection from the Main Q.
